Old 05-02-2004   #1
LightningGSX
Hellbound
How much of a reliabilty difference is there between the 360 deg and 270 deg bearings on the garrett T3/T4s? How about the Garrett turbine housing vs the PTE performance wise?
-Nulli Secundus-
Old 05-02-2004   #2
i just associate BAD with 270s. doesn't cheapturbo.com use those?
Old 05-02-2004   #3
I wouldn't run a 270 on car that constantly runs high boost like a DSM, they don't seem to hold up too long. Probably fine on Honda's running 7psi.
The Garrett 4-bolt outlet exhaust housing and the PTEs are good. The old Garrett/Turbonectics 5-bolt outlet exhaust housings are not as efficient.
Old 05-02-2004   #4
stay away from 270's. Yes cheapturbo.com uses 270 bearings. Just as ecoli stated. 270's work fine at low boost levels like Honda's use, but will more than likely fail when used under higher boost conditions like on DSM's.
Old 05-02-2004   #5
Raptor
ConArtist
Raptor's Avatar
Hey Eric, here is a basic article on it I thought you might find interesting.
Thrust bearing info
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 05-03-2004   #6
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
You can upgrade to a 360 thrust bearing at CheapTurbo for $75, which I (and everyone else) highly recommend.
Old 05-03-2004   #7
well my 60trim has produced 25psi for 6000miles and 35psi for a few passes at the track and 10pulls on the dyno. But I suppose this turbo would not last 100k like it should. Way to go cheapturbo.com.
Old 05-03-2004   #8
LightningGSX
Hellbound
Thanks for the answers, two other questions though.
Whats this "stage 3-5" turbine crap?
They only come with 2 different housings right(on the full Garret setup), the 4 bolt and the 5 bolt ford/chrysler one?
-Nulli Secundus-
Old 05-03-2004   #9
SuperSleeper
The stage 3-5 has to do with the aggressiveness of the turbine wheel (if I'm not mistaken)
Stage 5 would then be most effective in high RPM/high horsepower applications. Would be a little more laggy than the stage 3, however.
Old 05-03-2004   #10
Stage 3 and Stage 5 are names that Turbonetics uses for turbine wheels. The Stage 5 is a bigger wheel than the Stage 3. The Stage 3 is the same size as a T31 76-trim turbine wheel, the stage 5 is the same size as a T350 76-trim turbine wheel. The 10-bladed exhaust wheels are better than the old 11-bladed turbine wheels. I don't know if they even sell the 11-bladed ones nowdays. The exducer/inducer sizes on the stage 3 are 2.228"/2.559". The stage 5 is 2.437"/2.795". More possible power, more lag. We have done .48 A/R with the stage 5 on 1.8-2.0 motors. Similar power and slightly quicker spool than doing stage 3 with a .63 A/R. Stage 3 and .63 A/R is the most popular combo on DSMs and Hondas. If your going to run a larger than normal compressor wheel or want more lag or your trying to get every last bit of power out of a smaller comp wheel then you might want to try the stage 5 in a .63 A/R exhaust housing.
Old 05-12-2004   #11
SquackDiddy
Send a message via AIM to SquackDiddy Send a message via MSN to SquackDiddy
Thrust bearing info
thanks for the link. i learned yet another thing about turbos :bounce:
I am on suspension because I refuse to type a decent sentence.
SquackDiddy is offline   Reply With Quote
