Old 10-13-2010   #1
Road_Runner
Drives: 97 custom gst
Arrow woah CLUTCH HELP!
My clutch is getting pretty weak and sometime grindy if I try to drop it into second. Second is the worste. I need help in finding a new clutch. I don't want it to be crazy expensive, labor is bad enough. So if anyone knows where there are some cheap good clutches, let me know please.
*1997 Eclipse GST custom!
Road_Runner is offline   Reply With Quote
Old 10-13-2010   #2
Re: woah CLUTCH HELP!
Are you sure your clutch is the issue, and not the transmission itself?
Are you getting proper pedal engagement?
Is the clutch slipping?
Do you even know what I'm asking?
Old 10-13-2010   #3
Road_Runner
Yeah I'm pretty sure its the clutch. Its getting hard to push into gear sometimes even with the clutch to the floor. No its not slipping out of gear, just getting hard to get into gear.
Old 10-13-2010   #4
Have you tried adjusting the clutch master cylinder and bleeding the hydraulic system?
Old 10-13-2010   #5
Pour some clutch repair fluid in the breather hole on the top of the bellhousing.
Old 10-13-2010   #6
Road_Runner
Poor some what into the what? Lol I'm not to good and motors yet, but I'm trying. I just know the basics pluss a little. What's the bellhousing?
Old 10-13-2010   #7
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Its the round silver looking thing the part that covers your clutch flywheel etc. part of your transmission the mouth of it i guess. Closest part to the engine there you go, if that helps picture it.
Old 10-13-2010   #8
Sprinkle sawdust in there too..it acts as a friction material, and helps grip better.
Old 10-13-2010   #9
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
sounds like bad syncros if anything..
Originally Posted by 311evo
Old 10-13-2010   #10
I'd adjust your clutch first, under the dash, there's an adjustment nut on the clutch arm. If that doesn't work, you might need a clutch, but most likely your second gear synchro is shot. It's common on a lot of cars, especially ours.
Old 10-13-2010   #11
cmspaz
Walls need hugs too
cmspaz's Avatar
lrn2revmatch
Originally Posted by Trogdor
Old 10-14-2010   #12
Road_Runner
so replacing the clutch wont help?
Old 10-14-2010   #13
19TsiAwd90
19TsiAwd90's Avatar
lrn2revmatch
space bar broken?lol
why replace your cluth when your not sure thats the issue
Old 10-14-2010   #14
If your transmission only grinds going into a certain gear it is not your clutch, it is the transmission.
Old 10-14-2010   #15
19TsiAwd90
19TsiAwd90's Avatar
you should drain your tranny fluid and put syncomesh in heres a how to guide use penzoil syncomesh in stead of 75-90
http://www.dsmpurity.com/forum/showt...on-fluid.-(GST)
Old 10-18-2010   #16
Road_Runner
well it isnt only second gear that its hard to get into, thats just the most common one because thas usually the most common gear i use so i notice it most. but its hard to shift into all gears if the rpms are up. and down shifting is kinda tough too.
Old 10-18-2010   #17
19TsiAwd90
19TsiAwd90's Avatar
do what i said above you will notice a diffrence i had grinds in 2nd 3rd and 5th while driving under normal conditions not beating on it and now i rarely grind a gear unless im shifting at like 7k
