Old 10-20-2010   #1
Devildevil
Drives: 03 Evo 8 AS
FS: Lots of go fast goodies
I have some spare stuff laying around that I would like to sell.
We will start out with stock parts:
-Stock turbo manifold, 18k miles, excellent condition! $50
-Stock o2 housing, 18k miles, also excellent condition! $25
^^^ BOTH FOR $65^^^
-Stock Evo 8 Camshafts 18k miles, no issues. $75
Now onto other stuff...
-46mm external wastegate Used 964 miles, good condition. $75
-Garrett "T67" turbo Used 964 miles, saw 10psi ONCE on motor break in,
Great condition! no play. $680
~Compressor: Wheel: 67mm inducer / 84mm exducer
Housing A/R: .70 A/R
Housing: T04R with 4" inlet & 2.5" outlet
~Turbine / Exhaust: Wheel: P trim
Housing A/R: .84 A/R
Housing Style: Divided (twin scroll) T4 Housing with 3" V-band outlet
SILVER TURBO ON BOTTOM
Buschur Racing Coil On Plug this uses the msd dis 2 box. $650
-Garrett GT35R turbo Used 3k miles, Great condition, no play.
~Compressor: Wheel 61.4mm inducer / 82mm exducer
Housing: GT35r with 4" inlet & 2.5" outlet
~Turbine / Exhaust: Wheel 68mm
Housing: 84 trim .82 A/R
Housing Style: Divided (twin scroll) T3 housing with 3" V-band outlet
~Ball Bearing, Oil & Water cooled.
Turbo Trix turbo kit with GT35R listed above Lifetime warranty on manifold, flanged for tial 44mm v band gate. 3k miles. Coated.
Will include turbo, tial 44mm wastegate, 3" v band o2 housing, dump tube for EWG, fittings for turbo, oil feed line, etc. $2500
-Garrett GT4088R
~Used for 2 years ("years" meaning summers here), turbine wheel has some melted fins from anti lagged launch control. Still works, makes plenty of power, just doesnt make much of a difference in power between 20 to 30 psi. Can be fixed pretty cheap.
~Compressor: Wheel 63.5mm inducer / 88mm exducer
Housing A/R: .72 A/R
Housing: GT4088R (GT40R) painted black with 4" surge ported inlet & 2.5" outlet
~Turbine / Exhaust: Wheel 77mm
Housing: 78 trim and i will have to check if its the .85 or .95 A/R as i dont remember
100% right now
Housing Style: Divided (twin scroll) T4 housing with 3" V-band outlet
~Ball bearing, Oil & Water cooled.
$800
BLACK TURBO ON TOP
-Aeromotive A1000 Fuel Pump Used 964 miles, works great. $275
-Summit 12 gal. Fuel Cell Used 964 miles, works great, no leaks or issues. $80
-Aeromotive FPR Used 964 miles, works great, no issues. $125
- -10AN, -8AN, & -6AN stainless braided fuel line & fittings
Asst'd lengths, setup to run from cell, to pump, to lines, from lines to FPR, return to
cell. $ varies with what you want
^^^Full fuel setup stated above $700^^^
Royal Purple 5w-30 motor oil 11 bottles all still brand new and sealed. $60
-Autometer Phantom Gauges
~0-35psi boost, no vac
~Air/Fuel (narrow band)
POSSIBLY:
~Intake temp (would have to cap tapped I/C pipe to remove)
~EGT (would have to cap tapped exhaust to remove)
$Varies with which ones you want
Full Blown Double Pumper Brand new. With fittings $400
Quartermaster Twin Disk with Hydraulic TOB Used about 1200 miles, LOTS of life left on it, was thinking of going triple for the new setup is the only reason i have this up for consideration. $850
I will help with prices, shipping, etc where i can
Devildevil is offline   Reply With Quote
Old 10-21-2010   #2
Devildevil
Drives: 03 Evo 8 AS
Re: FS: Lots of go fast goodies
bump.
Sponsored by:
MAPerformance
http://www.maperformance.com
Old 10-25-2010   #3
OldSchoolMotors
Divided T3 manifold , willing to sell separate?
WWW.CLEVELAND4G63.COM
OldSchoolMotors is offline   Reply With Quote
Old 10-27-2010   #4
santa
Boost Spike
santa's Avatar
Send some pic's of the fuel cell to me please. Kj182 at msn
Thanks!
Old 10-28-2010   #5
Devildevil
Drives: 03 Evo 8 AS
pm'd you
Thanks!
email'd you
pm's answered.
BUMP.
Sponsored by:
MAPerformance
Old 10-29-2010   #6
BriK
BriK's Avatar
Drives: GG IX MR SE
By "stock turbo manifold" do you mean an exhaust manifold for a stock-framed turbo? For an Evo, not a DSM, I assume?
PM'ed as well.
BriK is offline   Reply With Quote
Old 10-30-2010   #7
Mon$tar
Drives: '90 Talon TSi AWD/ '91 Galant 1302/2000
So what are your FS prices? These look like the same price it'd cost new lol.
Mon$tar is offline   Reply With Quote
Old 10-30-2010   #8
Devildevil
Drives: 03 Evo 8 AS
PM'ed as well.
It is the factory exhaust manifold for the stock framed turbo off of an evo 8.
Pm'ing you back.
Everything is OBO.... and i'm pretty sure the only thing that is listed same as from a distributor is the double pumper. I have the pumps for it as well.
Sponsored by:
MAPerformance
