Old 10-29-2010   #1
'98 Eclipse GSX
Picked up an auto '98 Eclipse this afternoon.
It apparently has a spun rod bearing. Upon tearing it down in the next couple days I hope to decide what exactly I want to do with this car. It's not perfect but is a lot cleaner than my '95 and the plan is to make it a solid daily driver.
Mods:
Motor/Turbo/Go fast stuff
Rebuilt 6 bolt motor with 1g big rods and 1g pistions
Balance Shafts are removed
L19's
Felpro Perma Torque Head gasket
DKS Stage 2 cames (272's)
1g throttle body with fiav block off plate
JMF Race Intake Manifold
SBR/Kinetic FMIC
3" GM Maf
Tial Q BOV
3 MSD Plug wires and 1 random (hey it works)
JMF Copy coil relocater
Hallman Pro Manual Boost Controller
FP DSM 82HTA
FFWD Turbo bolts
FP Exhaust manifold
FP Intake
K&N filter
FP oil feed line with FP oil restrictor
FP Drain
FP Dump tube
FP 2.5" 02 housing
3" Megan Down Pipe (only exhaust on the car)
Apexi N1 cat back
-10 Catch can setup with JMF Deluxe Catch Can
Nitrous
Fuel
1600cc injectors
AEM Fuel rail
New oem fuel filter
-6an line from filter to rail
Aeromotive Fuel Pressure Gauge
Kenne Bell Boost-a-Pump
Single Walbro 255hp pump
Drivetrain/Suspension/tires/brakes
Rebuilt auto
Shift kit
Kiggly 6 bolt in a 2g kit - still need to order
Re-stalled stock converter - still need to order
Tein Flex coil overs
Prothane Motor mount inserts
Hawk HPS Brake pads
Non-abs car
AC removed
Old 10-29-2010   #2
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: '98 Eclipse GSX
<-Likes this
So when you say "daily driver" do you mean 10 seconds daily driver? lol nice pick up man. My friend was flippin through craigslist today and he saw this listed and it sparked his interest. I laughed. Anyways, good luck brad
pics or gtfo
Old 10-29-2010   #3
Re: '98 Eclipse GSX
Thanks Brian, you'll have to hit me up if you ever come back down to the cities.
I'd just like to convert this car to a manual, keep the turbo setup, put some bigger injectors in it, run some corn and bring it to Shane and have him work his magic on it and have a fun daily driver. No need to be the fastest or anything like that.
Old 10-29-2010   #4
Re: '98 Eclipse GSX
Good plan dude. You gonna sell the owdee now? Looks like a real clean car!
Old 10-30-2010   #5
hippiekiller
hippiekiller's Avatar
Re: '98 Eclipse GSX
Brad, you should buy my '95 and take all the parts from it, stuff it in this and ditch my shell. Just saying...
Old 10-30-2010   #6
Re: '98 Eclipse GSX
If you need a pedal assembly and what not, let me know also. My car is getting parted out.
Old 10-31-2010   #7
Re: '98 Eclipse GSX
I have my crappy '95 that i'll pull most parts off that I need to make it manual. I also have either this motor or a stock 6 bolt sitting in my shed that I can rebuilt. Thanks for the offer though!
I still have my '95 so I have a pedal assembly and the cables and most of everything else. I might need a couple things though. I'll shoot you a pm when I have a little more money
Thanks dude! Yea, as soon as I get this running and feel its reliable I'm going to try and seel the awdee as quickly as possible.
Finished pulling the motor yesterday afternoon, despite having the pull the whole passenger side hub because of a stuck axle. Hopeful to have some not so carnage pictures later today.
Old 11-01-2010   #8
Re: '98 Eclipse GSX
http://mitsustyle.com/forums/showpos...50&postcount=5
2 flex plate bolts fell out when I took off the converter and I was hoping that this was the "rod knock." I don't think thats the case any more.
Old 11-01-2010   #9
notsostockgalant
3g camaro owner
Drives: 88' camaro 400hp 327 sbc
Re: '98 Eclipse GSX
grab a set of oem bearings and plastigauge it after you take some emery cloth to the crank to remove any garbage, if theres no gouges in the crank that catch your fingernail and the plastigauge shows its within spec, id see no problem in re using any of that, i ran mine very little just to move it up to the garage after i lost oil pressure and the bearing was destroyed, seems like he may have caught it early enough.
How do the mains look?
notsostockgalant is offline   Reply With Quote
Old 11-02-2010   #10
Re: '98 Eclipse GSX
I think I'll try that and see if everything is in spec. I just remember reading that replacing a messed up bearing without really know why it went bad isn't the best idea. This is also going to be my daily driver once its up and running so I'd hate to have another rod bearing go out in a month or two and not have a way to get to work.
I didn't look at the mains. You guys think I should?
Old 11-02-2010   #11
Re: '98 Eclipse GSX
From the pics, I don't think the #4 journal is saveable.
Old 11-02-2010   #12
Re: '98 Eclipse GSX
Why is that? Sorry if its a dumb question, but I have never delt with a spun bearing before and want to know everything I can.
I've done some reading on it, but not enough to feel comfortable enough with it.
Old 11-03-2010   #13
Re: '98 Eclipse GSX
Looking at it a bit more I wont be able to throw some new bearings at it. I can feel lines on the crank with my fingernail.
I think I'll just look for a cheap manual tranny/transfer case and throw in the 6 bolt from my 95 or rebuilt the stock 6 bolt I have in my shed and jsut rock it like that.
Old 11-17-2010   #14
Re: '98 Eclipse GSX
A little update.
Tore apart the rest of the motor last night and every rod bearing was spun and almost all of the mains looked pretty rough. I'm just going to ditch this motor and then probably pick up another 7 bolt and just get this thing back on the road asap.
Awe, two cute little DSM's
And random pictures I took before running to bed before getting in trouble. Sorry they aren't great but some pictures are better than no pictures.
Old 11-17-2010   #15
Re: '98 Eclipse GSX
Looks like the bearings in the 1G I picked up. I'im going to put it back together and sell it as-is, I don't feel like replacing the short block, too many projects right now.
Old 11-17-2010   #16
Re: '98 Eclipse GSX
Are you going to polish the crank? or what are you all going to do to just put it back together?
Kiggly's kit for a 6 bolt in a 2g is cheaper than buying a new motor. I think I'm just going to put my motor/turbo setup from my '95 into this guy and let er buck. Then if I can sell my other car as a shell I'll have enough money to maybe get a nice converter and have a quick car again.
Hopefully start to put in some overtime here at work and get that kiggly kit ordered in a week or two.
Old 12-06-2010   #17
Re: '98 Eclipse GSX
You gonna swap everything into this car since you're trying to sell off the black 2g or what?
Old 12-06-2010   #18
Re: '98 Eclipse GSX
Yep, the motor/turbo set up will be going into this car and the black car will probably get parted out pretty hard core. I'll update the first post with an updated mod list of the parts this car will have on it
I just got sick of having a fast car that was a tin can. This car is complete and shouldn't be that much slower being full weight but still have all the little comforts like a radio and heat. haha
After I get it running with the auto I'll put it up for sale to try and get an evo though. If it doesn't sell before prime track season I'll put some slicks on it and try and make a few passes with it and go for broke.
Old 12-06-2010   #19
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: '98 Eclipse GSX
EvoStyle FTW, lol.
Originally Posted by Trogdor
Old 12-06-2010   #20
Re: '98 Eclipse GSX
9s?
