Old 11-03-2010   #1
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
So i just did my rod bearings on my stock 7-bolt with 150k on it.....pix
Picture 1
Huge pictures just for detail... the first picture you have to scroll around but youll find the chunk...So i'm hearing funky noices only doing warm up from the head... In picture 1 that really scares me, i'm unsure where that is coming from......crankwalk........!!!!!!!??????
Boostn2g is offline   Reply With Quote
Old 11-03-2010   #2
Re: So i just did my rod bearings on my stock 7-bolt with 150k on it.....pix
I'd normally ban someone for pictures that huge, but there is a cigar ad in the background so you pass for now.
That chunk in the first picture almost looks like a piece of a turbo thrust bearing.
Old 11-03-2010   #3
Find some smaller pictures so I can print them out to be on a billboard or some shit...
Old 11-03-2010   #4
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
ITS LIKE HAVING THE BEARINGS ONE INCH FROM MY FACE!!! OO MAI GAWD!!!!
PS I hope you had your crank turned.
Old 11-03-2010   #5
Resize pleez!
Buy my built block and be done
Old 11-04-2010   #6
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
How detailed are those pictures? LOL.....WOW Thrust bearing? can i replace those dropping the oil pan?
Old 11-04-2010   #7
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
What are you talkin about crank turned? i had to turn it to put on cyl 2 and 3 's new bearings
Old 11-04-2010   #8
LAWL's !!
Old 11-04-2010   #9
Boostn2g
Boostn2g's Avatar
Drives: 2g Talon
FUNNY? first time doing these bearings anyway. Only reason why i did them because i heard a knock only at 3k rpm. I installed acl race bearings, lubed, and torq'd, ive but on 300+ miles since and still runs like a champ, not bulding a 7 bolt just giving her more time to run so i can swap my 6 bolt
Old 11-04-2010   #10
He's laughing because 'turning a crank' means machining it, not actually flipping it 180° so you can get the other two rods. With as worn as the bearings look, the crank is probably in rough shape.
Aren't you supposed to measure clearances when you install new bearings?
I have a feeling you will be doing this again very soon....
Old 11-04-2010   #11
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
let me know how the 700 mile mark goes for you, thats when my engine exploded that I rebuilt without turning the crank. Pics of the block hole are mandatory.
