Old 12-16-2010   #1
89_Colt_GT
89_Colt_GT's Avatar
Drives: Swifty Crazy
Exclamation Help?? ...had misfire, fixed it, now the check engine light is on
I was having a misfire intermittent, sometimes near mid boost, sometimes at idle, bought new NGK plugs and Borg-Warner wires. no more misfire, however the check engine light came on and it is a super "lumpy" start-up.
My question is: is there a code scanner that works on an 89 dodge colt?
I havent really looked for one but IIRC there is a OBD-I port down there. suggestions help
1989 Colt GT
2013 Ford Focus
1999 Buell M2
89_Colt_GT is offline   Reply With Quote
Old 12-16-2010   #2
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: Help?? ...had misfire, fixed it, now the check engine light is on
find someone with an OBD-I scanner then
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 12-16-2010   #3
Not sure how similar the Colt ECU is to a 1g (I think they are the same no?) But this is on vfaq, and instructions on how to retrieve the code if you don't have a logger.
http://www.vfaq.com/index-main.html
Electrical>Retrieving Diagnostic Error Codes
There should be a list of codes along with instructions in there.
Again, not sure how similar this is to a 1g, but I figure it's worth a shot.
Old 12-17-2010   #4
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
I also found this. not sure if its right, but i assume it is. like most of the older cars you will probably have to use a jumper wire.
http://www.troublecodes.net/chrysler/92-93colt15.shtml
P.S. Google is awesome. good luck dude.
Shane Tune@ DB
Old 12-18-2010   #5
89_Colt_GT
89_Colt_GT's Avatar
my spiritual guide came to me and told me it's an Engine Temperature Control Sensor. Now to make a WTB ad for one
1989 Colt GT
2013 Ford Focus
1999 Buell M2
Old 01-02-2011   #6
89_Colt_GT
89_Colt_GT's Avatar
FIXED!! I used those blue quick splice connectors, I was still having a starting issue, I tested the resistance between the splice and the connector at the sensor. One wire had an error, turns out the splice didn't cut into the wire, just squished the plastic covering the wire, now she starts and runs like a beauty!!
1989 Colt GT
2013 Ford Focus
1999 Buell M2
