Old 12-18-2010   #1
89_Colt_GT
89_Colt_GT's Avatar
Drives: Swifty Crazy
WTB: Engine Coolant Temperature Sensors off 1g
pretty sure they're the same 1g/2g, I'll double check. But I need the lower one and the upper one. Upper is the one on top of the thermostat.
I was told to try the lower one first, so I'm gonna do that. Thanks
1989 Colt GT
2013 Ford Focus
1999 Buell M2
89_Colt_GT is offline   Reply With Quote
Old 12-19-2010   #2
jrohner
jrohner's Avatar
Re: WTB: Engine Coolant Temperature Sensors off 1g
1G & 2G seem to read different on the one for the gauge.
Old 12-19-2010   #3
89_Colt_GT
89_Colt_GT's Avatar
the gauge reads accurate, I'm wondering if the sensor on the bottom is the sensor for the gauge, being it is always in contact with the engine coolant, where as the top sensor is in contact when the thermostat opens?
1989 Colt GT
2013 Ford Focus
1999 Buell M2
Old 12-19-2010   #4
There should always be engine coolant on both sides of the thermostat, but the coolant on the engine side should be hotter then the radiator side until the thermostat opens. The 2 wire sensor below, which is next to the single wire sensor is the engine coolant temp sensor for the ECU, the single wire sensor is for the temp gauge in the dash. The 2 wire sensor on top for the 1g is for the 2nd radiator fan, which is for when the AC is running, or the temps get hot enough to trigger the 2nd radiator fan.
I should have a few extra coolant temp sensors for both the gauge and ecu for a 1g, let me know if you need one.
Old 12-19-2010   #5
sent you a text. I have a couple here
Old 12-19-2010   #6
89_Colt_GT
89_Colt_GT's Avatar
pushit2.0, please text me @ 651-274-6019. Thanks.
1989 Colt GT
2013 Ford Focus
1999 Buell M2
Old 12-19-2010   #7
I has no cell phone, you can pm me.
Old 12-21-2010   #8
89_Colt_GT
89_Colt_GT's Avatar
I replaced the sensor, no change, I'm thinking the wiring is bad, so I followed it up to the intake area, I'm just gonna wire a new connecter on. And hopefully that solves my issue. Once it gets started she purrs like a box of kittens, it's just that it takes 12 cranks to get lindsay to fire up. Sent you a PM too.
1989 Colt GT
2013 Ford Focus
1999 Buell M2
Old 12-21-2010   #9
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I'd put my money on the fact that it isn't causing the problem you're having.
Style's automotive engineer
Old 12-21-2010   #10
89_Colt_GT
89_Colt_GT's Avatar
that's what my check engine light says..
1989 Colt GT
2013 Ford Focus
1999 Buell M2
