Old 05-08-2004   #1
SquackDiddy
Send a message via AIM to SquackDiddy Send a message via MSN to SquackDiddy
for a exhaust have a 3 inch downpipe, no cat, 3 inch catback, but for the muffler use a stock one? would the stock muffler help or hurt? if it has the same results as other mufflers thatll be nice.
I am on suspension because I refuse to type a decent sentence.
SquackDiddy is offline   Reply With Quote
Old 05-08-2004   #2
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
If you take off the stock muffler off from the stock system, you get around 5 hp.
Think of exhaust flow like hot wax. The hotter it is the faster it flows, less pipe size needed, so at the end of the exh system the flow gets cooler and needs more pipe size to flow. :3gears:
Take her to the limit!
Old 05-08-2004   #3
LightningGSX
Hellbound
It would work, but it wouldn't do you much good.Its kinda like the saying "A chain is only as strong as its weakest link", in this case, the exhaust flow is only as good as the smallest part of the system.And like stated above, it gets even worse as the gas cools off.
-Nulli Secundus-
Old 05-08-2004   #4
SquackDiddy
ok so whats the best aftermarket muffler thats not to noisy?
Old 05-08-2004   #5
LightningGSX
Hellbound
That not a good question to ask, the definition of "noisy" will probably be different for each person.
-Nulli Secundus-
Old 05-08-2004   #6
Raptor
ConArtist
Raptor's Avatar
I have the perfect muffler for you Stop by the shop if you want to see one. I also have a used one that is in pretty decent shape that might work well for you and it wouldn't cost much.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
