Old 02-11-2011   #1
FS:89 orignal turbo mirage hatch
1989 mirage turbo hatch 1 of 1500 shipped to the US
It is an original 4g61t car.
vin: JA3CU54Z8KU10020
the build on here with pics and more info
http://evo123.net/showthread.php?t=640
or all the pics on photobucket
http://s122.photobucket.com/albums/o...e/89%20mirage/
Mods
4g63 engine has 7k on it (car gets driven 1 day a week)
.020 over 2g pistons on 1g rods, arp main studs,arp head studs,arp rod bolts,acl race bearings rods and mains, new oil pump with bse kit, new water pump, new timing set, 90 oil cooler set up.
Head
Decked, 5 angle valve job, evo 3 sodium filled valves, bc springs and retainers,evo 3 cams, mitsu mls head gasket, light port and polish job, stock intake manifold, 90 n/a throttle body, Taylor 10mm wires, jdm (Mitsubishi) valve cover
Turbo set up
Evo 3 mhi 16g, evo 3 turbo manifold,evo 3 o2 housing, 3in down pipe, 3in high flow cat,3in cat back with thermal muffler. Fmic with shorty piping , tial bov,gm 3in mas, gm maft translator. Oil catch can,evo 8 injectors, 190 wall pump
Brakes and suspension
95 mirage front knuckles with new wheel bearings,1g dsm 5lug hubs with new studs,rear 5 lug swap,new struts and shocks front and rear, new ball joints, new tie rod ends, 94 gsx 2 piston front brakes, slotted and drilled rotors front and back
Tranny
90 awd dsm tranny with welded center diff to make fwd, new front axels, act awd flywheel, act 2100 p.p with new oem disk, redline fluids, new master and slave cylinders
Inside
90 EPROM ecu socked with stock chip, auto meter - electric oil pressure, boost, volt gauges, Jensen flip out DVD 7in screen deck, kicker door and rear speakers, 95 mirage shifter box and shortened shifter, 95 mirage shifter cables, power windows out of a colt gt
Outside
All oem panels on the car. Chrome 90 mirage sedan grill, hella super tone horns, 1g dsm washer bottle set up
Wheels
3g eclipse 17in oem rims with summer tires
As of right now the car is running n/a with the stock 90 header, reman 90 ecu, injen intake with stock mas. All the turbo parts will come with the car just have not put them on since it got cold out side and the engine was getting broken in.
There is no rust holes on it at all the car came from ATL . The body is showing its age. The paint is faded and there is scratches and hail dents on it. The front seats are letting go at the seams and the drives has a hole in it.
Extras that will go with the car
Complete power window set up wiring,,regulators,switchs,locks and rods. Drivers and pass side windows,evo 3 m’s springs and evo 3 kyb adjustable front struts, rear sub frame from a dsm. Center concel both pieces. Rear hatch plastic panels,antena, front axels that need new boots, there is other parts as well that will go with the car.
3000.00 for the car and all the extra parts
