Old 02-15-2011   #1
Owned
Drives: 2g
Wierd Misfires. 2g Tsi
Ok so i been having weird misfires ever since replacing my old T25. 157k, New plugs, 450cc injectors, stock SMIC+piping, 1g bov adapter+ bov, replaced front bank o2 sensor, old stock cat. converter... While im driving on the highway (without boost) ill have a misfire and a weird smell will fill the cockpit once an awhile, my car wont boost past 5psi sometimes without misfiring/fuel cutting but will sometimes hold at 8-9 on 3/4 throttle but never will allow me to WOT. EGR is blocked off and fuel pressure solinoid removed, but these things where still happening before I did the EGR mod. I haven't had a chance to boost leak again after a failed attempt with the cheap one I made before, but i couldn't imaging a boost leak limiting me to 5 PSI on such a simple setup?? This was never a problem until I replaced my turbo with a T28.
Things I plan on trying or possible issues/suggestions.
I would like to Boost leak test again,
Should I RTV the BOV gasket?
Should I RTV the EGR block off gasket?
Buy a new coil pack?
I have a FIC injector seal kit I have and need to install...
I have/waiting on FPR and install that...
Would the injectors be bad?
More or less I'm looking for more opinions so I'm not spending money on pointless things I dont need replaced..I've already dumped 2k on this car and its still stock, WOW.
Owned is offline   Reply With Quote
