Old 02-28-2011   #1
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Perkul8r's 91 Galant VR4 1055/2000
So I was messing around and called my Aunt looking for a running and driving car. I have been trying to buy her husbands Galant VR4 for years. Well. She said that due to it needing a clutch and having trans problems.
The last time i seen the car it looked alot better. lol. The paint is really bad on it. And the interior is in dire need of a good cleaning. The car does run good though. Even with a slipping clutch I was able to drive it 250 miles back home. The clutch did slip anytime you get into boost. But i just took it slow.
I already have the parts to fix the clutch issue. Only thing I am concerned about is the trans issues. If you put it into first and let the clutch out it just pops out. I did do some looking and i see that the bracket holding the cables on the trans is loose. Gonna tighten that up and check the cables for adjustment and see what happens.
Any way here are some pics.
Its dirty as hell and needs a good cleaning. Which will get done this weekend. Hoping to have it up and going by next week.
