Old 03-02-2011   #1
v8klla
v8klla's Avatar
MAP Dyno Results: O2 Eliminator / LICP / Rev3 Intake Mani / Tubular Exhaust Mani
We recently wrapped up a 2.4L FP Black build for a customer (check out his thread here) with underwhelming results. Ideas were being tossed around in the aforementioned thread in regards to potential bottlenecks so we decided to embrace this opportunity and swap out some of the components with MAP equivalents. Enjoy!
MAP Standard O2 Housing / eBay 3" Downpipe to MAP 3" O2 Eliminator
Most people looking at a list of mods wouldn't assume there would be a significant difference between a standard aftermarket O2 housing / downpipe combination and our O2 Eliminator...they would be wrong +23.55whp and +41.17ft/lbs is pretty significant in my book!
Injen LICP to MAP LICP
After the LICP swap the power curve was still a bit wavy but the big dip at 6500 all but disappeared. Couple that with an 8whp peak gain and I'm pretty happy with the results considering it was aftermarket vs aftermarket.
Stock IM & TB to MAP Rev3 IM & Full Blown 70mm TB
I'm not too excited about the peak gains, but two large areas have improved substantially (37whp and 32 ft/lbs just over 6k). It still seems to be choking up top though.
Stock Exhaust Manifold to MAP Short Runner Tubular Manifold
I'm a little more excited about this one It saw peak gains of 26whp and 14ft/lbs with even larger gains of 43whp and 34ft/lbs at 6500 rpms! It's also pertinent to note that these gains were realized with one less pound of boost, we tried to match it up but the clutch was starting to hate life at these power levels
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
