Old 03-06-2011   #1
RS98GSX
RS98GSX's Avatar
Drives: White on White 98 GSX
Weird noise
I have a weird humming noise coming from my engine bay. This noise is new I’ve never heard it before, I’m thinking it might be my tensioner or my harmonic balancer and maybe a pully not spinning putting drag on a belt what do you guys think?
http://www.youtube.com/watch?v=NOU9OfbjS-k
and go easy on the color comentary that goes with the vid
RS98GSX is offline   Reply With Quote
Old 03-06-2011   #2
Spikesoftail
Spikesoftail's Avatar
Drives: 96 Talon Tsi AWD Auto
Re: Weird noise
Noises are almost impossibe to diagose without actually being at the vehicle. You can try pulling the belts off 1 by 1 and narrowing it down that way.
"Call amberlamps"
Spikesoftail is offline   Reply With Quote
Old 03-06-2011   #3
93gtpeater
Drives: cbr 1000rr repsol
Re: Weird noise
It could be a bunch of things. Timing belt rubbing, or it jump a tooth, and the worsat one of all bs shaft bearing falling out. Take of your belts and see if it make the noise. And check you timing.
Old 03-06-2011   #4
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Weird noise
That noise brings back bad memory's ha. My car made a similar noise and it ended up being my oil pump committing a slow and painful suicidal death. . .http://mitsustyle.com/forums/showthread.php?t=26546 the speed or hum of the noise increased as RPM's increased as well. If the noise doesn't clear, i would try and spin your oil pump pulley as the last option, see if it perhaps is that. It could be something loose like you mentioned as well.
Old 03-06-2011   #5
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Weird noise
Sounds a ton like a bearing.
So yeah, take off belts one by one.
Originally Posted by Trogdor
Old 03-07-2011   #6
Re: Weird noise
The first thing that comes to mind is the power steering pump, but also the AC compressor or alternator.
Old 03-07-2011   #7
RS98GSX
RS98GSX's Avatar
Re: Weird noise
No ac so its either the timing belt or alternator belt (a pully driven by one of those belts)
And No balance shaft...so a earing didnt fall out
I could also tell you guys that the srs light come on and I was told a while back that that ment your altonator was going bad so that pully could be seizing up
Old 03-07-2011   #8
RS98GSX
RS98GSX's Avatar
Re: Weird noise
Did the good ol screwdriver to ear test today at as many points as I could an it was strongest at the alternator which im guessing is seezing (<--- spelled wrong) up, I also believe its going out because of the SRS light going on and off and the radio started going in and out right when this started to happen. So now the real question is do I go buy a new alt. and put it in in the parking lot at school or haul it home to MN and find one back home. just gotta find a car trailer now instead of renting on from uhaul
Old 03-07-2011   #9
Re: Weird noise
The obvious answer would be to fix it before you take it on a road trip.
Old 03-07-2011   #10
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Weird noise
Talk to Gabe (Laser) on DSTA, he might have some space to work on it.
You can do it on the ground with the wheel turned and the inner fender liner unbolted if you're a small guy, but it's easier to do with the front end in the air, as that pivot pin can be a pain. It'll need to come out the top, so the PS pump will have to be moved out of the way (but the lines can stay connected). Expect about an hour if it's your first time.
Old 03-08-2011   #11
RS98GSX
RS98GSX's Avatar
Re: Weird noise
Im not driving it anywhere my dad was gonna come trailer it home from school so i can fix it at home and I can get one for free from a buddy at home
Old 03-21-2011   #12
RS98GSX
RS98GSX's Avatar
Re: Weird noise
Installed saturn alt. works car runs like a champ now and no noise! thanks for the help guys
