Old 03-09-2011   #1
plow420
plow420's Avatar
Drives: 96 eclipse gsx
What do you think of the g4cs
Hi, I've been in the DSM game now for about 3 years. First i cracked a piston after i was tuned for e85 on my first motor about 7 months or so ago. I love my car and felt it was necessary to build a 6 bolt 4g63. I ended up doing the wiseco/eagle combo with acl tri metal bearings and and everything else done as well.
To get back to the point of why i want to know info. about the g4cs is because my motor spun number 4 rod bearing after 2500 miles. Everything ran amazing up until then also. No problems what so ever.
I found a g4cs at a local junk yard and what i was planning on doing is to take that block and use that with my 2g head that i was already using on my 6 bolt build.
I do know that the stock rods on the g4cs only hold around 350 wheel so is that about the limit on the motor? I have two cars both currently down and i think it would be the best route to build this motor until it blows or any other suggestions anyone has would be great. Thanks........and money is kind of limited until I get another job
plow420 is offline   Reply With Quote
