Old 05-20-2011   #1
SpyderGSX07
SpyderGSX07's Avatar
Drives: 97 GSX Spyder/99 Chev S-10
Brake Line Tuck (eclipse 2g)
Does anyone have any suggestions in doing a brake line tuck?? i am in the middle of the process of cleaning the firewall up. and i have seen a brake line tuck done.. i just want a few suggestions... and i am considering putting that brake distributer block line thing inside of the window cowl. the unit that is mounted on the firewall with 6 brake lines going into it. some advice in this project would be great!! Thanks!!
SpyderGSX07 is offline   Reply With Quote
Old 05-20-2011   #2
SpyderGSX07
Re: Brake Line Tuck (eclipse 2g)
Old 05-20-2011   #3
You probably have to custom bend your own lines or something for that. Or go all steel braided? I don't know. My .02 never is constructive.
Old 05-21-2011   #4
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
on the Hondas, they run the brake lines from the brake master into the firewall immediately and put the proportioning valve behind there. Depends how much stuff you have behind there (blower motor, dash wiring etc...)
'04 Honda Ricer: stock
Old 05-21-2011   #5
SpyderGSX07
well i do know i have to bend my own lines. but i am undecided where to put the distribution block.. inside window cowl... inside the cabin on the fire wall... i donno where it would be more convienient.. and i did eliminate the entire hvac system.. so plenty of room there...
