Old 07-11-2011   #1
kram0170
FS: 1997 Eagle Talon TSi AWD - 546WHP
For Sale: 1997 Eagle Talon TSi AWD FULLY BUILT - 546WHP - $10985
For sale is a rare fully built 1997 Eagle Talon TSi AWD. I am the second owner and bought this car completely stock back in 2001. Over the years, I have spared few expenses to build the fastest, most comfortable, daily-driven Talon I could. Over $50K invested over the years!! And I have dozens and dozens of receipts to prove it! Just look at all of the parts listed below.
This is NOT some stripped down weekend-only car or trailer queen. This car was built with the best parts and the most skilled labor so that it can be as civilized as it can get for a 546 AWHP (see dyno graph) car. The car doesn't need to be tinkered with or re-tuned every day, the tune has been dialed in, so there is nothing left to do but drive.
All engine/transmission/major repair work has been done by MAPerformance (MAP).
  • The engine is a 9 out of 10. It only has about 5,000 miles on it. It is broken in with NO ISSUES! It is a fully built 2.3L STROKER 6-bolt by MAPerformance with a ball-bearing Garrett GT35R turbo. The car has low end torque and boost comes on strong at about 3000rpm and holds all the way to the 7500rpm rev limit. But because this car has an electronic boost controller, the boost is civilized at part throttle too. It has NO known problems. The car still has all of the stock features like A/C and cruise. The engine has only seen Mobil 1 synthetic.
  • The body is a 9.5 out of 10. It has 106K miles on it and has only one tiny door ding because a few years ago I had $1000 worth of paintless dent removal done on the car. The paint is original and smoother and glossier than most new cars!
  • The interior is a 9.5 out of 10. It looks like it did new! All of the electronics are nicely hidden away from sight. This is a perfect SLEEPER car - the interior, other than the A-pillar gauges, looks stock.
This car has won multiple times in the 2G class at the DSM cookout.
I'm selling this car because I bought a different car and find myself not driving this car too often any more.
If you're thinking I want a bit much for "just" a modded Talon, you have to understand that I am OCD when it comes to my car. I demand perfection and believe that I have come as close to that as possible with this car.
Please feel free to contact me, with any questions or to set up a test drive, via PM or Email: okrampf@gmail.com or Call/Text: (612)325-5680.
This car has a clean title. Serious buyers only. All sales are final.
I am willing to drive up to 300 miles from the Cities to meet the buyer.
I accept cash or cashiers check. Price is slightly negotiable.
--------------- SPECS ---------------
Engine (about 5000 miles):
ALL WORK DONE BY MAP
  • 2.3L 6-bolt FULLY-BUILT Stroker
  • 85.5mm Bore
  • Wiseco 8.5:1 Pistons
  • Eagle Rods
  • ARP Rod Bolts
  • FP (Forced Performance) 2X Cams
  • Balance Shaft Eliminator Kit
  • ARP L19 HD Head Studs
  • 4G64 Alternator
  • 2G Stage 2.5 PORTED Head with revised lifters and SuperTech 1mm oversized valves
  • Fel-Pro MLS head gasket
  • Greddy KEVLAR Timing Belt
  • Slowboy oil pan
  • Mishimoto aluminum radiator
  • 160 degree thermostat
  • 2 SPAL slim-line fans (10" AND 12") – This car will not overheat even in 90 degree humid summer days.
  • MAP Custom air-cooled oil cooler with early 1G oil filter housing
  • MAP Custom catch can with -8AN lines
  • Powdercoated gloss black valve cover with polished letters
  • Custom-length MSD 8.5mm spark plug wires
  • COLD A/C
  • Cruise-control
Turbo/Fuel/Exhaust:
  • Garrett GT35R running 25psi of boost with NO Knock on E85
  • DNP Tubular T3 equal-length exhaust manifold covered with exhaust wrap
  • Tial 38mm external wastegate
  • APEXi Black AVC-R Electronic boost controller - smooth, linear boost curve, both part-throttle and full.
  • MAP Custom O2 housing and downpipe with 3" stainless steel V-band
  • MAP Custom 4" cold-air intake pipe
  • FIC 1600cc injectors, also included are FIC 1050cc injectors (1600cc for e85, 1050cc for 92 pump gas with reduced boost)
  • Aeromotive fuel pressure regulator with gauge
  • Walbro 255HP fuel pump
  • Thermal R&D 3" Exhaust
Intercooler/Intake:
  • HRC front-mount intercooler with stock bumper reinforcement still intact
  • MAP Custom 3" intercooler piping
  • GM 3" MAF
  • Greddy Type-S blow off valve
  • *PORTED* JDM CYCLONE Intake manifold with functioning vacuum secondary butterflies (awesome low-end torque AND great high-RPM breathing)
  • Ported throttle body
Electronics:
  • DSMLink V3 ECU
  • AEM UEGO wideband with gauge
  • APEXi 3.5 bar MAP sensor
  • Dynatek ARC-2 electronic ignition amplifier
  • VDO Boost and EGT gauges in LoTek A-pillar mount
Transmission/Drivetrain/Suspension/Brakes/Wheels/Tires:
  • Shep Stage IV fully-built transmission - $5K alone, about 5000 miles, grinds a little bit into reverse)
  • Quarter Master Twin Disc clutch (about 3000 miles, fully street-able, holds ALL of the power with absolutely NO slippage. It is certainly nosier than a normal single-disc clutch, but you get used to it.)
  • 4-Spider center differential
  • B&M Edge short shifter
  • Tokico Illumina 5-way adjustable shocks
  • Eibach Pro-Kit springs
  • Front StopTech Premium rotors (New)
  • Rear Powerslot slotted rotors
  • Stainless-steel brake lines
  • Axxis Metal Master Ultimate brake pads front and rear (New)
  • 18x8 TSW Cadwell wheels (less than 1000 miles, like new!)
  • 235/45R18 Sumitomo HTR ZIII tires (95% tread left)
Audio/Alarm:
  • Pioneer DEH-P8600MP deck
  • Infinity Kappa front component speakers with external crossovers
  • Kenwood 4-channel amp custom mounted underneath front passenger seat for front and rear speakers
  • Rockford Fosgate 10" sub in a custom enclosure with a bridged Rockford Fosgate amp and .5 farad cap
  • Lots and lots of Dynamat in the doors, hatch, and quarter panels.
  • Viper 791XV 2-way alarm with shock and hood sensors
I'm sure I've probably missed a few items. Buyer will receive receipts for all of the parts mentioned.
--------------- PHOTOS ---------------
Click on photo for full size.
Have you downloaded the interweb today?
kram0170 is offline   Reply With Quote
