Old 08-07-2011   #1
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Anyone good at tuning?
Just finished up with my winter build and figured out I suck at tuning. I have V3 and installed some BM 1450's, switched to e-85, and switched to speed density. I can get it to start when I feather the gas a little but as soon as I let off the gas, it dies. My WB seems to jump around and I can't seem to get it dialed in with my deadtimes. Is there anyone that can lend a hand one day that has some experience tuning e-85 and SD? I live in Maple Plain.
Old 08-07-2011   #2
Re: Anyone good at tuning?
Call shane at DB! That should be your next stop anyways
Old 08-07-2011   #3
^ this man speaks the truth!
Old 08-07-2011   #4
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
But I need a tune before I can bring it there. I want to be able to drive it to where I get it tuned. I am either going to DB or MAP. I just don't feel like blowing it up, I tuned my car last year but that was with 93 and 780 injectors. E-85 and SD are new to me and can't seem to get whole of it. Anyone local familiar with it?
Old 08-07-2011   #5
+1 for Shane
Old 08-07-2011   #6
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Do you still have the stock mass? getting it started on the stock mass will be alot easer. then you can either drive it to Shane. Or get it close on the mass then switch to speed density. If you havent already sighn up on the dsmlink forum there is alot more info on there.
11.35 @ 120mph
Old 08-07-2011   #7
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
I do have a stock mass but don't have a pipe to fit it to my Turbo and when I did my wire tuck, I made it so the stock connector is located towards the back of the engine bay. Does Shane make house calls? Haha that would be sweet. If he could hook me up with a tune to get there, I would for sure take it to him.
Old 08-07-2011   #8
He doesn't really do house calls but I'd be willing to bet he could give you a base config that could at least get you to DB (on no boost).
Old 08-08-2011   #9
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Well I guess I will give him a call and see what he can do. They should come up with something like DB to go, would be amazing.
Old 08-08-2011   #10
They being DB... lol. just rent a trailer
Old 08-08-2011   #11
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Ya I just through that twice to bring my car to MAP for some Fab work, would like to drive it and save $57. Just my luck, Shane is out for the day so I have to wait until tomorrow.
Old 08-08-2011   #12
Fran05
Drives: DSM
You should be able to dial-in base settings and drive the car to DB out of boost.
What is your deadtime and global for the injectors? Base fuel pressure? All ethanol in the tank or some pump mixed in too?
Speed density requires proper working map sensor among a couple other things. Do you have everything wired in correctly? Consult this link http://www.ecmtuning.com/wiki/sdsetup
Old 08-08-2011   #13
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Global is -53.5% and deadtime is 435. FP is set at 45 and it is all e-85 in tank. I have the bundle from ecmtuning along with their plug and play cable. I have V3 but just can't seem to get it to idle right. I am gonna check my electrical timing tonight and give it another shot.
Old 08-08-2011   #14
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Here I finally got a log for you guys to take a look at. I have a Mac so im not sure if you can view it if you don't have the driver for it but take a look anyway.
How do you link the log? Says its invalid.
Old 08-08-2011   #15
way2fastalon
IS Broken :-/
way2fastalon's Avatar
well e85 is not idle friendly ... my car refuse's to idle on it ... but besides the point
speed density is not that hard to set up i believe dsmlink v3 has a auto tune function that is set up for base tune .. what dose your wide band say. That is your friend . Did you read the manual, it explains how speed density works and how to set it up .
www.ecmlink.com read the pdf on set up its painfull to read and understand but it can be explained
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 08-09-2011   #16
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
I read that but I found out my omni 4 bar is reading -29 When then the car is off which explains why the car is dumping so much fuel in. Now I just have to figure out if the sensor is bad or if I messed something up.
Old 08-09-2011   #17
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Here is a link to my thread on ecmlink if your a member you can view the log.
http://www.dsmlink.com/forums/showthread.php?t=61423
Old 08-09-2011   #18
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Is there anyone that has the SD package from ecumenical, be willing to let me swap in the known good omni 4 bar to see if it is my sensor that is bad?
Old 08-13-2011   #19
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Well my injectors may be leaking so I pulled them and shipped them to FIC. I also bought an easy tune box to help get these going. Will let you know what FIC says and if the easy tune box helps.
Old 09-10-2011   #20
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
As long as you have the speed density air flow sensor hooked up with links SD plug it should be easy as pie to get it running to get it to DB on V3 link. On E85 since you have a 2g you should have a base FP of 43psi, injector size should be what ever size you are using, and stoichiometric ratio should be 9.8526 or pretty much 9.8. have that set correctly and then use this http://www.ecmtuning.com/wiki/sdsetup to get SD set correctly, using the SD table in link provided to you and then running combinedFT it should really be pretty easy because thats what link does, makes it easy. You should be good to drive to DB to get your timming advanced and add boost because that's all they will probably really be doing or should do since you can get it running good yourself using links SD table.
