Old 08-08-2011   #1
Swanny
Swanny's Avatar
Drives: 2G Talon
rotor / rim spacer?
Im missing some sort of plastic spacer that goes around the center portion of the rotor that allow my wheels to be center on the rotor... I only have one on the back. Anyone know what this is? And where to find my size?
Swanny is offline   Reply With Quote
Old 08-08-2011   #2
Swanny
Swanny's Avatar
Drives: 2G Talon
Re: rotor / rim spacer?
Without spacer
Rear spacer
Old 08-09-2011   #3
Swanny
Swanny's Avatar
Drives: 2G Talon
Can a mod fix the pictures
Old 08-11-2011   #4
Swanny
Swanny's Avatar
Drives: 2G Talon
Anyone??
Old 08-16-2011   #5
polishmafia
Smells like cat poop
polishmafia's Avatar
They are called hubcentric rings. Stock rims are made to fit around the hub of the car. Aftermarket wheels typically come with a larger bore size so they can fit multiple car types. The ring centers the wheel around the hub and also allows the wheel to correctly carry the weight of the car.
To find the size you need, go here -> http://adaptitusa.com/referencebook.htm
You can find them online by searching google, or call a local Discount Tire.
Old 08-18-2011   #6
Swanny
Swanny's Avatar
Drives: 2G Talon
Figured someone from a tire shop would know... I get slight shaking from not having these in @ around 65-70mph then fades away. there slightly off and knock the lug nuts loose....either way in this case im looking at the center bore of 67.1? Thank you for the reply!
Old 08-18-2011   #7
polishmafia
Get some before you shear off your wheel studs and send a wheel flying into another car. Most cars made for sale in the US are made with the hub bearing the weight of the car. If you have aftermarket wheels without the rings, the lugs bear the weight of the car - which they are not made for.
Old 08-24-2011   #8
Swanny
Swanny's Avatar
Drives: 2G Talon
I pick some up at discount tire for 15$
Old 08-27-2011   #9
89_Colt_GT
89_Colt_GT's Avatar
Drives: Swifty Crazy
^^Is that pre-tense or past-tense? I could use a few
1989 Colt GT
2013 Ford Focus
1999 Buell M2
89_Colt_GT is offline   Reply With Quote
