Old 08-31-2011   #1
Revobasher
Revobasher's Avatar
Drives: 14 Evo X GSR
New Guy.. Picked up an Evo
Some of you may already know me since I have been posting over on EVOMN. Just picked my Evo from a member on evom.
Current mod list is below.. first plan of action as you guys prob saw is e85 conversion!
410whp and 375 lb-ft @ 27psi on pump 93.
Performance:
Ivey Tuned
CBRD BBK Full ported Turbo
PTE 1000cc Injectors
GSC S1 Cams
WORKS Aperture TB Seals
ETS 3.5” IC with ETS upper pipe
Muse LICP
Walbro In-Tank 255lph Fuel Pump
APS dual-vent BOV
Perrin Intake
Hallman Pro MBC
MAP Ported/Polished/Coated Exhaust Manifold
MAP o2 Housing
DC Sports Catless Downpipe
GReddy Evo2 Catback
Suspension:
Robispec KW V3 Clubsports
Robispec Rear Sway Bar
Whiteline Front Roll Center Kit
Whiteline Rear Trailing Arm Bushings
Whiteline Rear Bump Steer Kit
Vorshlag High Castor Front Camber Plates
Stoppage:
StopTech Slotted Rotors, front and rear
Hawk HPS Front Pads
StopTech Street Rear Pads
StopTech Stainless Braided Lines
Motul Fluid
Trans:
5 Speed RS Swap with all new parts
Spec Stage 3+ Clutch with Billet Flywheel
Speed Source Shifter Base and Cable Bushings
Wheels\Tires:
Summer:
Enkei RPF1: 17x9.5 +18 front, +38 rear
Falken Azenis RT-615k 255/40/17
Drop Engineering open-ended Lugs
Winter:
Stock MR BBS
225/45/17 Semperit Winter Sports
Interior:
Autometer triple dash pod
STACK Gauges-- Wideband, Oil Pressure, Boost
Trustz Gauge Overlays
Alpine CDA-105 Headunit
Boston Acoustics SC65 Speakers
Exterior:
Evo 7 Tail Lights
______________
2014 CB Evo X GSR - 323/324 @ 26lbs (Mustang Dyno)
2012 IS250 F Sport - TOTALLED
2006 Evo IX MR - ​SOLD
Revobasher is offline   Reply With Quote
