Old 09-19-2011   #1
Gravy
Who's this guy?
FS: 91 Dodge stealth
Time to get out of the game, college life is too expensive and the ride has to go sadly.
Asking price: $5,0000.00 OBO
It's a 1991 Red Dodge Stealth with 142,xxx miles(just under but will be test driving it soon) and as it is I've still drove it to and from work a few times and to and from St. Cloud with no problems until I get into boost. Currently doesn't want to boost due to no tune and wrong gap on plugs. Was running 25psi last year on same set up but haven't had time to get it tuned.
Currently has:
Twin TD04 13g turbo's
SAFC
GM Maft translator running blow through
550cc injectors(450cc's included with sale)
AFPR (E-bay knock off)
DB Performance MBC
Autometer Wide band O2 sensor and boost gauge mounted on A-piller
2.5" intercooler
FMIC (~30" x 3" x 15")
Palm pilot currently has dead batteries, includes cables
3" turbo back exhaust with no cats
Tires have very little wear on them
New CV axles and sway bar links as well as both lower ball joints replaced last winter
Headlights were converted to run a H4 aftermarket projector headlight(included with sale) and bulbs are now an OE style similar size bulb(high beam doesn't work with current light set up though but does with the projectors)
Pair of 10" cheap subs and amp in the rear, nothing to make you deaf but gives a good sound
CD deck with a dying faceplate. Have to push it in sometimes for it to light up(that way since i bought the car)
The Bad:
ECS currently doesn't work. unplugged and sitting in pole barn right now
Exhaust leak which is planned on getting fixed this week if time permits with some street tunning.
Rubber mounts on carrier bearing have some play but new carrier from Mitsubishi is included with sale($80.00)
Gear fluid is coming up on 2 years old but also planing on doing later this week
Likes to grind going into fifth gear a little but has since i bought it about 3 years ago.
AC has been removed after blowing the AC fitting off the line
Hanging pipe on drivers side has been changed since picture and now runs straight back.
Will be working on the car either Thursday through Saturday and will update with anything completed on the car by than.
Can Text to 763 370 2160 with questions, calls from unknown numbers often go ignored. Vehicle is currently stored in Saint Francis.
Gravy
Last edited by Gravy; 09-19-2011 at 03:18 PM.. Reason: Price drop to $5,000.00 after seeing similar cars/millage.
Old 09-19-2011   #2
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: FS: 91 Dodge stealth
Originally Posted by Gravy View Post
Asking price: $6,0000.00 OBO
For $60000.00 this thing better have sex with me.
Old 09-19-2011   #3
Gravy
Who's this guy?
I will have sex with you
