Old 09-21-2011   #1
URV8SUX
URV8SUX's Avatar
Midway shootout Oct.9th
Who's in...
Old 09-21-2011   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Midway shootout Oct.9th
I might be down depending on how things go this weekend. is it $50 plus the class buy in?
11.35 @ 120mph
Old 09-22-2011   #3
URV8SUX
URV8SUX's Avatar
Yeah I think that's how it is but if you win you win money! !!
I'm just going to use it for a TNT and try to beat up on some V8s!
Here are the classes
Originally Posted by AtoB Team View Post
RULES FOR 2011 MIDWAY SHOOT OUT
REAL STREET
Heads Up racing on a Pro Tree.
Street legal with current tabs and proof of insurance.
13.5 x 30 Max tire size permitted (Must be street legal with DOT #)
Factory body, wheel opening must retain factory appearance.
Must have Stock front and rear frame rails, factory location firewall and factory floors. All vehicles must have hoods.
Inner surface of frame rail must remain un-modified. (Tires must remain inside wheel well).
Must have stock type front and rear suspension Any power adder ok.
Coilovers allowed in factory location.
No wheelie bars.
Must run mufflers exiting no farther forward than the back edge of driver’s seat. Must have working head lights & Tail lights.
Must maintain full interior with finished appearance, including one functioning side windows*(See Below), the only exception being the removal of the back seat. (If rear seat is removed, floor must have finished appearance all the way up to the package tray.)
*One full-sized window adjacent to the driver that operates in the OEM fashion. (i.e. goes up & down)
PRO STREET
Heads Up racing on a Pro Tree..
Any size DOT tire or max size10.5 x 30 slick allowed. (No “W” tires)
Any power adder
Back Half Cars permitted; Four Link or ladder bars are permitted. Tube Chassis vehicles permitted. All vehicles must have hoods. (Excluding pre-1950 “Street Rod” type using OE style radiator support grill shell.)
*One full-sized window adjacent to the driver that operates in the OEM fashion. (i.e. goes up & down.)up & down.) . .
ONE CLASS OF HANDICAP BRACKET RACING.
• All cars must have head lights & tail lights
Old 09-22-2011   #4
Mark Leasure
Mark Leasure's Avatar
I'm in. Was very happy that my compression check was 160 across all cylinders. Can't believe it!
Old 09-22-2011   #5
Ronnie S
Not sure if I can swing this one but I'd like to go.
Ronnie S is offline   Reply With Quote
Old 09-22-2011   #6
As of right now I plan on going.
Old 09-28-2011   #7
carltalon
carltalon's Avatar
I plan on going down on saturday and doing some testing. trying to get a 10 before the snow flys. Then I'll stay down to watch the shootout on sunday. anyone else plan on making a weekend out of it?
11.35 @ 120mph
Old 10-08-2011   #8
Mark Leasure
I'm here, anyone else coming this weekend? Lots of fast turbo cars, all v8's tho.
Old 10-08-2011   #9
Mark Leasure
Just ran a 9.90 @ 154.7 on 40 psi, track is hooking so its time to turn the boost up!
Old 10-08-2011   #10
Mark Leasure
Beat a big block Camero that ran a 9.98!
Old 10-08-2011   #11
Nice work man, you getting plenty of runs down there?
Old 10-08-2011   #12
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
good work keep us posted!
Old 10-10-2011   #13
well.....
swifty posted pics of mark's car on fb, looks like it didn't end good.
Old 10-10-2011   #14
Mark Leasure
Yep, didn't end well. Broke a shep transfer case, $1750..
Old 10-10-2011   #15
You've had some really bad luck the last month or so with drivetrain parts...
Old 10-10-2011   #16
that turned my stomach a bit, I take it that's the 300M shaft one?
That's nuts. Does your suspension need addressing? I can't imagine there is a lot left to mess with on your setup.
Any others? i know nate was there.
Old 10-10-2011   #17
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Would've loved to go but I was in Vegas getting married
Old 10-10-2011   #18
Mark Leasure
Pic of what I found when I took the exhaust off the car! When I removed the exhaust section the gear that interfaces the tail shaft fell on the ground. The housing is all busted up too. Called shep today, sounds like they don't have any more upgraded TXcases available. I hope he will run another batch. It lasted 20+ 1.5-1.6 60 foot launches. I was not pushing it hard compared to others that use it.
Old 10-10-2011   #19
Holy fahk! Sorry dude, but to go fast, gotta break shit...you'll have it fixed in notime I'm sure! Good luck and thanks for sharing the stories!
Old 10-10-2011   #20
I've never seen that kind of breakage.
