Old 09-24-2011   #1
Amadeous
Drives: 97 Gst
Clutch line problems
I have a 97 Gst and my clutch line that goes to the actuator(release cylinder) on the bottom of the transmission keeps leaking.. i tried to repair it myself but nothing i did would stop the leak so i took it in to a shop. they "fixed" it and it lasted for about a month and started to leak again. any ideas on what might be the problem?
Amadeous is offline   Reply With Quote
Old 09-24-2011   #2
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: Clutch line problems
Get a new slave cylinder
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 09-25-2011   #3
Amadeous
Drives: 97 Gst
i did and it is still doing it, i have a new clutch line on the way so hopefully that will do it. could clutch pedal adjustment or anything else put too much pressure on the system?
Old 09-25-2011   #4
GsXtUrBo98
GsXtUrBo98's Avatar
I guess idk, but I went through 2 slave cylinders before I got one that didn't leak so you might just need another new one...
98 GSX (built)
03 BBY EVO dd
Old 09-25-2011   #5
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Did you get a new slave or rebuild your old one?
Being the lowest point of the system moisture and crud can accumulate in the slave over time and cause it to become rusted/pitted. Sometimed a little sand paper and new seals fixes it. Sometimes it's so bad you need to replace it.
Old 09-25-2011   #6
Amadeous
Drives: 97 Gst
when i went to get a new one , it ended up not being the right one i guess so i gutted the new one and cleaned up my old one. i checked for any defects in the old one, cleaned it all up and put the new parts in it and replaced the fittings. it worked for a day and then started leaking out of the line again.
Old 09-25-2011   #7
GsXtUrBo98
GsXtUrBo98's Avatar
Get a new one from brookdale Mitsubishi
98 GSX (built)
03 BBY EVO dd
Old 09-30-2011   #8
Amadeous
Drives: 97 Gst
well its not official yet but i finally got my new clutch line in and i think i fixed it. the only problem is i had to bypass the clutch dampener.. hopefully that doesn't effect anything long run . its running good otherwise.
