Old 11-14-2011   #1
portum89
portum89's Avatar
Bad oil leak from exhaust ports
Hi just trying to get some thoughts on my problem, ive done some research and working on the car when i get time...its a 95 TSi,50 trim (brand new) supporting mods....basically HG went out (stock hg and bolts at the time), HG got replaced, after replacement, ran the car for about 10mins, and "clap clap clap" valves hit the piston (lil plastic piece from cover fell into oil pump pulley causing it to jump teeth)...after that bought a head from a guy supposedly rebuilt with 10k (he said by steve gb) (looked as such, hot tanked etc) put the head back on...and started the car, first thing i noticed is lots of smoke after about 2 mins, let it run to see if itd stop, but no, never stopped...took ex. manifold off, and there it is oil on the ex. ports mainly cyl#1 then 2 3 and barely 4....as far as i could tell some oil on top of the piston as well...havent done a comp test yet, talked to a machinist his thoughts on it are that when valves hit the piston the rings mightve gotten off their seat causing it to leak that bad, also said if valve seals or guides were bad it wouldnt leak that much and it would somehow stop when warm, mine keeps leaking...ill post pics
Important notes that might help: HG (felpro) mightve gotten scratched or damaged since head moved on it a couple times when putting the head on, havent retorqued the studs (arps), taking the head off soon. Thanks
95 talon tsi awd...pte scm 5031 /950ccs on corn / gsc s1's / comp stage 4 / 12.8 @113mph - SOLD
99 Spyder GS-T 16g / 264's / 550ccs / Reflash OWN
Old 11-14-2011   #2
portum89
portum89's Avatar
Re: Bad oil leak from exhaust ports
Old 11-14-2011   #3
portum89
portum89's Avatar
Old 11-14-2011   #4
portum89
portum89's Avatar
CYL#4
CYL#3
CYL#2
CYL#1 the worst
Old 11-14-2011   #5
93gtpeater
Drives: cbr 1000rr repsol
If your ring are bad one piston I would think the car would start and run funny. The valve seals could be junk. I would have the head checked before digging into the motor. I never heard of the rings unseating from it hitting the valves. But anything can happen. Have the head checked then go from there.
Old 11-14-2011   #6
portum89
portum89's Avatar
Just an update i pulled the head off and the hg had oil on it on both sides, also on top of the block there was oil and coolant, the pistons had coolant on them...thinking my hg wasnt fully sealing...posting pics shortly
Old 11-14-2011   #7
portum89
portum89's Avatar
oil on top of block and coolant on pistons...
Old 11-14-2011   #8
Get some A1/H11 headstuds. Was that a Permatorque?
Old 11-15-2011   #9
portum89
portum89's Avatar
nope just a regular parts store felpro, doubt block is 100% straight so i went with that. I could use a permatorque, hoping its just the HG since its not so cheap ha.
Old 11-15-2011   #10
Get some good studs too.
Old 11-15-2011   #11
the arps were new they replaced the streched stock bolts
Old 11-15-2011   #12
Those regular parts store headgaskets are often junk on DSMs. I have had a couple DSMs blow them for no reason, no knock at all, at around 300awhp.
Old 11-15-2011   #13
portum89
portum89's Avatar
some are, car was barely ran after head swap, just started it and all the sudden the leak was there, so probably ran for about 10mins if so, im leaning towards incorrect sealing of the hg, i did the tq sequence a lil different, i did work my way from center to sides etc etc..just a lil different sequence, im guessing it caused it to not seal , also sending out the head to be checked just to make sure my guides and seals are all good...thanks for the input!
Old 11-23-2011   #14
CarPsyco84
CarPsyco84's Avatar
That oil could be from just pulling it apart? I've seen that exact issue before, valve seals, specifically on the exhaust valves, but just do them all.
-When in doubt, Moar RPM.
Old 11-23-2011   #15
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Check valve guides and seals. Obviously the car was smoking. When was it smoking?
Converted to LS
Old 11-23-2011   #16
portum89
portum89's Avatar
since startup never stopped, im getting the head checked by gosh might just build it.
