Old 11-14-2011   #1
Swanny
Swanny's Avatar
Drives: 2G Talon
FS: 1995 Eagle Talon TSI, Red, Rust-Free, $3,700
---3,700$$$..OR .Accepting reasonable best offers for serious buyers only. If you don't have cash or proof of being in the market to spend a couple grand on a car, I WONT let people take it out on joy rides----
Up for sale is a beautiful, fire red, rust-free 1995 Eagle Talon TSI FWD! At 150,000 miles, I became the third owner of the vehicle since the fall of 2010. Before ownership this car was an original California car, made its way to New York, since then Minnesota. Interior is grey cloth which I would rate at 7.5/10 for a vehicle this age, there is a cigarette hole on the front passenger seat and one on the rear seat from previous owners(s), the exterior would be a 7/10, some door dings and clear coat paint fade in the rear and a ding on the driver side fender. I bought this car knowing I picked up another DSM and soon there would be problems. With-in the last 35,000 miles give-or-take different parts were put on when needed at different times, much maintenance has been done and 80% of the receipts are in-hand.
Maintenance/Parts/Upgrades:
-Engine-
170,000 on the body.
6 bolt swap/ 7 bolt head combo installed @ 162,070 miles currently with 35,000 miles on the motor and going up
2G exhaust manifold port matched for Big 16G turbo and matching gasket.
Big 16G with 2G o2 housing & 1G oil return line @ 11PSI
New ITM front case and gasket
VR Speed 16G J-pipe.
Stock OEM 450cc injectors and fuel pump combo.
Braided high pressure oil feed plumped to oil filter housing.
New 3G revised lifters. (smooth motor)
ACL racing rod bearings.
New comedic head gaskets.
ARP head studs torque to specifications.
New FIC injectors seal kit.
New Dura last Battery, 800CCA
K&N Air filter
New coolant temp sensor
1G blow-off valve.
Newer Alternator
True 2.5" HKS exhaust with test pipe bolted to a 3" muffler, stock downpipe.
New Bosch front bank 02 sensor.
New spark plugs, NGK iridium 3764 gapped .028.
New Goodyear belts
New OEM timing belt, water pump and accessories.
MAP EGR block-off plate.
-Transmission/Suspension-
Stock transmission
KYB fronts & GR-2 rear struts with Eibach springs dropped 1.3" (rears not installed).
New synchromesh Pennzoil transmission fluid.
New OEM clutch.
8LB Fidanza flywheel locally bought (no receipt).
New OEM slave cylinder.
New OEM lateral control arm with ball joints, passenger & driver side. (warranties)
New OEM axles, passenger & driver side (warranties)
NEW OEM tie rods, passenger and driver side (warranties)
Alignment done at Tires Plus with specifications graph still on hand (might need another one)
BRAND NEW TREAD, 225/50/16 Firestone ovals & 16'' Discount tire aftermarket rims. (Any tire issues are replaced free)
Miscellaneous-
New wiper blades front and back.
New negative battery terminal cable.
10,000k HID headlamp bulbs
Stock Fog lights with H3 PIAA yellow bulbs.
New OEM rotors & brakes front and back
EBay fuel pressure regulator (not hooked up)
EBay JDM tinted A/F and Boost gauges.
35% Window tint
Cruise control delete
-Summary-
Clean title, break-in procedure was done with two oil changes at the first 500 miles, and one at 1,000 miles then oil was changed every 3,000 miles with Valvoline full synthetic 10w-30. The transmission is original which feels and shifts great. That is all the information I am able to provide, I have kept very good care of this car. As you can tell I'm very organized and put a lot into the sale of this car and will reflect the quality and time put in this car, does have oil pan leak and speedo sensor needs to be installed!. Thank you. call/text 763-237-4798 ALEX
Update: car has black hood, Alpine Radio, Newer 2G Throttle body with gaskets & FIAV O-ring.
I have a spare door white 2G door, couple 2G throttle body's, and I'm sure some other random stuff I will be including in the sale.
Swanny is offline   Reply With Quote
Old 11-14-2011   #2
Swanny
Swanny's Avatar
Drives: 2G Talon
Re: FS: 1995 Eagle Talon TSI, Red, Rust-Free, 4,500$
Updated the list with a few new parts i forgot to mention. I am also fixing the Oil leak tonight.
Thank you
Old 11-18-2011   #3
DSM-is-LOVE
Dream Motors All Day!
DSM-is-LOVE's Avatar
Drives: 03 Evo VIII
why you selling?
2003 Evo VIII
aka Lucy
Old 11-20-2011   #4
Swanny
Swanny's Avatar
Drives: 2G Talon
We need a practical daily driver, this one starts and drives everytime but doesn't deserve to be in snow
Old 11-21-2011   #5
Swanny
Swanny's Avatar
Drives: 2G Talon
Offers?
Old 11-22-2011   #6
Swanny
Swanny's Avatar
Drives: 2G Talon
I'm replacing the belts with OEM tomorrow, also broke the plastic side panel on the door today.:-(..... I will be adding more pictures sometime
Old 11-26-2011   #7
Swanny
Swanny's Avatar
Drives: 2G Talon
4000. Also the front and rear motor mounts are solid. No wheel hop lol
Old 12-01-2011   #8
Swanny
Swanny's Avatar
Drives: 2G Talon
Bump. Rotating the tires this weekend
Old 12-07-2011   #9
Swanny
Swanny's Avatar
Drives: 2G Talon
Replacing wheel bearing/hub side this weekend. Price is still 4000.
Old 03-15-2012   #10
Swanny
Swanny's Avatar
Drives: 2G Talon
Drunk bump. Ill regret this later. Needs front brake and wouldn't hurt to do the fuel filter, Come test drive. 4000$
Edit: has an Alpine Radio now
aswan7920@yahoo.com
Text 609-997-9930
Old 03-19-2012   #11
Swanny
Swanny's Avatar
Drives: 2G Talon
3900
Old 03-19-2012   #12
girl come with?
Old 03-19-2012   #13
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
^yeah at least for a day...shes hawt
2006 WW IX RS 396/404 - SOLD
Old 03-19-2012   #14
Swanny
Swanny's Avatar
Drives: 2G Talon
Re: FS: 1995 Eagle Talon TSI, Red, Rust-Free, $4,500
I have 2 pending buyers for 4k! tomorrow she might be gone (not the girl)
Old 03-20-2012   #15
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Oh Alex, you know the girl always goes with the car. Lol. Whats next for you and Olga?
Old 03-20-2012   #16
Swanny
Swanny's Avatar
Drives: 2G Talon
Lol.
Going to look at a BMW M3 with minor bolt ons tomorrow for her
I'll have a DSM next winter, hopefully sooner
Old 03-20-2012   #17
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Better be awd don't be stupid and screw with that Fwd.
Nice, M3 would probably keep her around. What year?
Old 03-20-2012   #18
Swanny
Swanny's Avatar
Drives: 2G Talon
Old 03-20-2012   #19
Swanny
Swanny's Avatar
Drives: 2G Talon
Ya we could all agree about the FWD thing. My 2nd, and last FWD.
The M3 is a 95....Little Old but I don't mind & will be a perfect car for her.
Old 03-20-2012   #20
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Your just feeding the fire for the leg humpers. Lol. You drinking right now?
I like that year of M3s. I was looking at a 4 door 3 series around that year
