Old 05-21-2004   #1
lower throttle body block off plate
just like that one, should take about 2 minutes to make with the proper tools (which i don't have)
.....and harry, i need it by tommarrow
Old 05-21-2004   #2
Enes
Enes's Avatar
what used to be in that place?
-E
Old 05-21-2004   #3
fmicmatt
-E
I think.....Throttle body heater and Intake temp sensor.
If you bypass theTB heater hoses......there is a plastic temp sensor that will over heat and melt, causing Idle problems in some cars.
-Matt
Old 05-21-2004   #4
-E
ISC/FIAV assembly. But I guess I've never seen someone block off that entire lower half. I've seen it done like this to just block off the FIAV and so you can reroute your coolant lines.
Old 05-21-2004   #5
yeah, you pretty much only need the FIAV if you drive your car in cold weather, and the ISC seems to only be necesarry if you have AC. i'm just trying to get rid of an idle problem and some wires in the process
