Old 03-12-2012   #1
psychorunner
psychorunner's Avatar
Drives: 2002 Subaru WRX STI
2002 STi Swapped WRX
SOLD!
Some info on the Bugeye body and any additions other than the swap itself
115,000 miles on the body, 95,000 on the engine/tranny
VIN# JF1GD29672G54459
STI "Pink" lowering springs
24mm whiteline swaybar
24mm Cobb adjustable swaybar
Kartboy solid endlinks
255lph Walbro fuel pump
Steel braided brake lines
Steel braided clutch line
Grimmspeed BCS
ERZ catted downpipe
Perrin twin tip CBE
AEM intake pipe with K&N cone filter
Tuned by Nuke
5x114 BBS Bronze BBS Wheels with summer tires (sorry, they are up in MN right now, more details on the tires soon)
5x114 BBS Silver BBS Wheels with winter tires (Dunlop Grasspic DS-2)
Samco intercooler hoses
Gimmick turbo inlet
Godspeed TMIC
Cobb turbo heatshield
Interior:
AEM wideband
Prosport Electronic Boost Gauge.
Both monted on A pillar pod
Center counsel painted black, black 6 CD changer, black hazard switch, polished plate that goes around the shifter.
Door card with carbon fiber fabric
Carbon fiber vent trim.
Stock WRX subwoofer
Here is a list of major components that were swapped:
EJ257 Long Block
VF39 Turbo
2005 STI wiring harness (Back seat forward)
STI ECU
STI ABS Controller (Left Stock Hardlines)
STI Struts with "Pink" lowering springs
STI 6spd Transmission, axles, drive shaft, R180 rear diff, fully operational DCCD.
STI 5x114.3 Brembo Brakes (Front rotors and front right brake caliper replaced March 2011)
STI Seats (front and rear)
STI Steering rack and Steering column
Front Subframe.
Interior:
STI dashboard, center console, steering wheel, 2005 HVAC system (AC does not work, but all essential parts are installed), STI gauge cluster, working DCCD controls, 2005 STI security system (imobilizer).
STI parts not swapped:
Control Arms
Lateral links
Rear subframe
Master Cylinder
Slave Cylinder
Grey 5 CD Changer
Blue STI Carpet and Mats
STI door cards
Radiator, Radiator Fans
Fuel tank
Info on the donor car:
VIN#: JF1GD70605L52304
Purchased from Marx All in One, LLC in October of 2010.
The STI was involved in a single car rollover.
At the time of purchase the odometer read 76,000 miles.
I have all the paperwork from this purchase. Even a carfax report.
I think I caught everything. If I missed something or anything is unclear let me know. All STI parts came from the same donor car.
Pros:
Since the swap was completed this car has been trailered to Virginia, drove back and drove multiple times to Ft Leonardwood, MO and back to Minnesota. It is in sound mechanical condition. No fluid leaks. Mechanically in great shape. Body and interior are in good shape. DCCD works, HVAC system works, Runs great!
Cons:
A/C doesn't work, but everything is installed. I never fixed it because I thought I might remove it completely.
Horn doesn't work
No rear diff temp sensor (lights up on dash)
Airbag light is on. In my limited spare time I'll try to track that down too.
Paint job on the hood doesn't match the best. But goes unnoticed to most.
Last winter I hit the ditch pretty hard, replaced front bumper and pass side axle.
Here's a few pics from the swap:
http://s999.photobucket.com/albums/a...%20WRX%20Swap/
This image has been resized. Click this bar to view the full image. The original image is sized 960x640 and is 154KB.
This image has been resized. Click this bar to view the full image. The original image is sized 960x640 and is 138KB.
This image has been resized. Click this bar to view the full image. The original image is sized 960x640 and is 194KB.
This image has been resized. Click this bar to view the full image. The original image is sized 960x640 and is 149KB.
Pictures thanks to EagleTalonGuy
SOLD!!SOLD!!
psychorunner is offline   Reply With Quote
