Old 06-26-2012   #1
4seasons69
4seasons69's Avatar
my new project
Well as some of you know I bought swiftys talon and since most of you already kinda know the car I wont go into too much detail about it other than what is currently going on with it and what I'm doing to it.
I bought the car figuring It I would be pretty set. It just needed to be tuned for new injectors and I'd have an awesome car to putz around in this summer. Well with the way my luck goes I'm about 90 percent sure something went wrong with the #3 injector (i'm going to have them bench tested to verify) and the cylinder pretty much ate it's self. they were brand new injectors too. I removed the cylinder head to inspect the damage. the cylinder head and piston were quite melted in cylinder 3 and one of the intake valves broke or melted off and did a number on the cylinder wall in cyl3.
Ok where I'm sitting now for the cylinder head. I have a good core to have my parts swapped into and it will need new valves for cyl 3 and it will have to be machined for the over sized valves. I'm debating whether or not to have it ported and polished too.
As for the block I'm not sure if I can get away with just honing it out so I'm going to pull the block and bring it someplace (not sure where yet) to have it checked out and see what the best route to go with it is. Idk if you can have a 4g63 sleeved or if it's just better to bore it out and go with over sized pistons. I would like to reuse as many of the parts as I can since all the rods look good and 3 of the pistons should be reusable. In regarding the block if anybody who has some experience with engine building as any advice please feel free to chime in. It will be greatly appreciated
and then there is the turbo. a bunch of metal went through the exhaust and dinged up the turbine wheel pretty bad so it will at least need a new exhaust wheel and a rebuild. depending on what ends up happening with the block I might look into upgrading to a billet version of the gt4294 or look into a gt4202/gtx4202
Sorry this is such a long post but that is kind of the short version lol
Old 06-26-2012   #2
4seasons69
4seasons69's Avatar
Re: my new project
Here are some pictures of the carnage
ID:	12657   Click image for larger version
ID:	12658   Click image for larger version
ID:	12660   Click image for larger version
Old 06-26-2012   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: my new project
Congrats on the new purchase! Perhaps maybe it will see the track now. Lol
As far as a place to bring it to get looked over. Motors by gosh is a good place. There located right next to DB.
Are those the FIC 2150s? I've heard they were having issues but I can't remember what the issues were.
Good luck with the car
Old 06-26-2012   #4
4seasons69
4seasons69's Avatar
Re: my new project
It will see the track eventually lol but I just hope to get her back on the road sometime this summer but we'll see I guess. Yes they are fic 2150s. I'll have to look into what kind of issues they're having with them
Old 06-26-2012   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: my new project
All I could fibd for failures doing a quick goggle search was that of storage. If they were not stored properly and cleaned water could get in causing irreversible failure.
Old 06-26-2012   #6
Re: my new project
Could have dropped a valve or broke a valve and have all that happen too.
Old 06-26-2012   #7
4seasons69
4seasons69's Avatar
Re: my new project
thats good to know. Im not sure if they were put in last fall or this spring but I know he got them from someone on here brand new unopened in the box.
That would make sense too. I guess I was leaning towards the injectors cause after it came off the dyno it was never beat on and I was just cruising when it happened. Im also leaning towards the injectors cause if you look at the picture of them you can see that 3 are starting to get dirty from the E85 and one still looks brand new. The one that still looks new was the one in the cylinder thats messed up and since its still so clean (I could be wrong) I would assume it wasn't flowing enough fuel. Im going to get them bench tested asap so I know whether or not the injectors are good
Old 08-03-2012   #8
4seasons69
4seasons69's Avatar
Re: my new project
Here's a little update of where things are sitting right now. I finally was able to get the injectors bench tested and they tested good. The flow and pattern are basically identical on all of them. So it's looking like its just a broken valve that's the culprit.
The shortblock is up at MAP right now being built. Had to get a new block, front cover, then we're putting different pistons in it (wiseco hd's), we're reusing my crank and rods, and putting a main girdle in it too.
It will still probably be a few weeks until I get it back then the head will be going to the head shop.
Old 08-04-2012   #9
Re: my new project
Ouch. Sucks it caused so much carnage.
Old 08-04-2012   #10
Re: my new project
X2. I'd cry.
Old 08-05-2012   #11
4seasons69
4seasons69's Avatar
Re: my new project
X2. I'd cry.
Lol! I kind of wanted to cry! I guess it's just part of playing with cars lol
Old 10-03-2012   #12
4seasons69
4seasons69's Avatar
Re: my new project
A little update on the car. I got my shortblock on Monday. It's a MAP stage 2 with a kiggley main girdle. So i can concentrate on the head now. I'm not 100 percent sure what route I want to go with the head yet. I'm going to order a rebuild kit for the twin disk then the shortblock will be going back into the car. It will be nice to finally be able to do some work on it.
Old 10-03-2012   #13
Re: my new project
Looks like the carnage I experienced when I had a valve fail too. I was gently cruising at 50mph when it happened to me. Never did figure out the reason why but valve failure was the only yhing that made any sense. The stock valves are a 2 piece design, so I guess it could be possible.
Good luck getting her back up and running.
Old 10-03-2012   #14
4seasons69
4seasons69's Avatar
Re: my new project
Lol very similar I was cruising at 60. Mine weren't stock valves though. Now that I got the shortblock the hard parts over should be up and running before it snows. Then tuned and driveable next spring
Old 10-04-2012   #15
4seasons69
4seasons69's Avatar
Re: my new project
I dropped the cylinder Head off at the head shop this morning and they said they think a valve seat dropped and that's what caused the valve to break. They also said that every valve hit a piston and is bent. Not sure what happened there either.
Old 10-04-2012   #16
Re: my new project
^mistimed? .
Old 10-04-2012   #17
4seasons69
4seasons69's Avatar
Re: my new project
Yeah idk everything swiftys told me about the engine that was in it seems to have checked out for the most part. He said he got the valves from Brent Rau so either the valves were bent when he got them, it was mistimed, or the cams were degreed wrong or the cam gears slipped. Idk lol. Pm me and elaborate on what you've heard if you don't mind.
Old 10-04-2012   #18
Re: my new project
PM sent.
Old 10-06-2012   #19
Re: my new project
Dang Shawn. Good luck on the rebuild, it'll be awesome to see that thing driving around!
Old 10-06-2012   #20
4seasons69
4seasons69's Avatar
Re: my new project
Thanks! The head will be done this week or next. So just a few miscellaneous parts and and the the engine is going back together. The just need to get the cams redegreed and the engine will be going back in. It will be up and running sometime I am the next month or two. Then work some bugs out and get it tuned next spring and she'll be ready to rock
