Old 07-10-2012   #1
DavidPHumes
Drives: Turbo LSx FC RX-7
Parting out vs. selling whole car
I'm just getting fed up with dealing with DSMs. I guess maybe I'm just not made for it, but when daily driving a 500AWHP DSM I guess it can get a bit tiring. I already have a project/fun car so I really don't need both.
Here's my dilemma: sell the car as is or part it out? I'd want at least $10k for the car as is. Parted out I think it's worth a LOT more.
3rd owner
98,000 miles
1998 GSX AWD
No rust (NONE on strut towers at ALL)
No major dings, scratches, etc. other than a dent on the hood
If I were to part out the car, do the following prices seem reasonable?
Engine:
DSMlink version 3 (with ECU and cable) - $700
6 bolt 2.4L (Eagle forged rods, Wiseco forged pistons, 8.8:1) - POSSIBLE bad head gasket (compression and leak down are both good though) - $3,000
Felpro PermaTorque headgasket
ARP head studs
1G head (ported, polished and gasket matched)
Forced Performance dual valve springs
Forced Performance FP3X cams with adjustable cam gears
Tial 44mm external wastegate - $100
Forced Performance HTA GT3582R - $1,200
SFP exhaust manifold (it has been welded previously) - $100
Polyeutrethane engine mounts - $40
Magnus intake manifold - $400
Road Race Engineering 3" downpipe - $150
Apexi 3" catback - $300
Setrab oil cooler - $200
Apexi Skyline FMIC with tubing - $800
Fuel:
Walbro 255LPH in-tank, Bosch 044 in-line, -8AN feed and return - $200
Aeromotive FPR - $75
Aeromotive stainless fuel filter - $50
FIC fuel rails - $90
FIC BlueMAX 1250cc injectors - $300
Drivetrain:
Shep Stage 4 transmission (with 4 spider center differential) - $1,750
PPT twin disk clutch and flywheel with Isuzu slave - $600
Suspension:
Tein Flex coilovers with EDFC controller - $1,100
RM front sway bar - $100
RRE custom rear sway bar - $250
13" Baer Claw brakes (rotors, calipers, mounting brackets, hardware, pads and stainless lines) - $750
Rear strut tower brace - $50
17" Motegi Tracklite (flat black) with newer Goodyear Eagle F1 225/45/17 - $900
Interior/Miscellaneous:
AEM Huego digital wideband - $150
Autometer 30PSI boost gauge - $150
Greddy Profec B Spec II digital boost controller - $300
DavidPHumes is offline   Reply With Quote
