Old 07-16-2012   #1
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
WTB: transmission bracket and 92 shifter cable mount.
I need the part that bolts to the transmission to the mount on the passenger side. I also need the shifter cable bracket for a 1g.
-Colin
Old 07-16-2012   #2
Re: WTB: transmission bracket and 92 shifter cable mount.
I should have both will take a look
Old 07-16-2012   #3
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Thanks Mark.
-Colin
Old 07-17-2012   #4
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Make sure you get the shifter cable from an actual 91-94 car, I believe that a 90 shifter cable and bracket will not work on a newer car but you can do 90 trannys in a newer vehicle and use a 91-94 shifter cable and get a short shifter, you just can do a newer tranny in an older car without switching the cables so basically you need a 91-94 cable.
Old 07-17-2012   #5
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Cool story bro. I am fully aware. Thanks for the info newb.
-Colin
Old 07-17-2012   #6
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
also, to the left and up is first gear, left and down is second gear, center up is 3rd...
Style's automotive engineer
Old 07-18-2012   #7
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Is R for racing then?
-Colin
Old 07-18-2012   #8
derrecks92talontsi
Drives: 92 talon awd
I am sure I have one to but I am in rochester man
derrecks92talontsi is offline   Reply With Quote
Old 07-18-2012   #9
boostintsi1990
boostintsi1990's Avatar
Drives: 90 TSI AWD
I got a 91+ base cables with no rips and brackets let me know if you still need any of this.
boostintsi1990 is offline   Reply With Quote
