Old 05-27-2004   #1
Enes
Enes's Avatar
are 2g cam gears fit/replace 2g cam gears..
i think my intake cam gear is bent for some reason.. not spining straight.. i can't say how come or why because its never been out of the car.. but all i know is that its bent..
it wobles left to right a bit... go figure..
since i already have a 91 head sitting i supose i could take that cam gear and pull it off, you think it will fit?
-E
Old 05-27-2004   #2
check your post? 2G gears will fit into a 2G?
if the cam gears wabbling, I'd think something else is messed up in the head as well. (or is it that the bolt that holds the cam gear on "loose"?
Just go aftermarket if your going to be swapping anyways!. they're not that expensive if I remember correctly. I know that's probably what I'm going to be the next thing I do when I upgrade my Springs/Retainers.
Old 05-27-2004   #3
Replace it, why take the chance?
Old 05-27-2004   #4
Enes
Enes's Avatar
which aftermarket one would you guys recomend?
-E
Old 05-27-2004   #5
I have the Fidanza gears, the price seems good, and they are quality pieces. I like them.
It's worth it just to have the ability to adjust the timing of the cams if needed. Especially if you degree your cams in.
Old 05-27-2004   #6
Enes
Enes's Avatar
thats the thing, i rather spend the $200 on a FPR instead of stupid cam gear... i haven't touched anything on the cams so i don't really need it.
I thin i'll just try to get the free factory one's for now .. spending too much money on the car alrady anyways...
maybe if it could get me some flames out the exhaust? maybe then i'll get them jk afcourse..
-E
Old 05-27-2004   #7
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Just geta stocker from someone. Or a new one from Mitsu. It's like $35.
'04 Honda Ricer: stock
Old 05-27-2004   #8
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I have a set of 1G cam gears. If you want you could have one or both for free. Just let me know.
That is assuming they would work.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
