Old 05-27-2004   #1
hooked it up, turned the key, no LED action. it says the plug is a shitty fit, and it is, so i tried bending the pins a bit to make them fit better but still no go. maybe i should just slather on some dielectric grease...i dunno
how have you other maft-ers got your shiz working?
Old 05-27-2004   #2
Enes
Enes's Avatar
hold your horses.. i will be doing mine tonight!! yaay!! after i take a head, turbo, exh and intake manifolds ... dsm like is after that
-E
Old 05-27-2004   #3
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
I broke out the soldering iron when I put in John's.
Old 05-27-2004   #4
Enes
Enes's Avatar
that is what i was tempted to do as well.. because it looks flymsy as hell!
-E
Old 05-27-2004   #5
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
I didn't have a problem at all hooking mine up, I've taken it in and out quite a few times too.
Have you tried having someone wiggle the connector (see if LEDS will come on) to make sure the MAFT is good and not defective?
Mines a 2G so maybe its a better fit?
good luck.
Old 05-27-2004   #6
I just hooked everything up and everything worked The plug is kinda crappy becuase it doesnt have a clip but miine stays together.
Old 05-28-2004   #7
Plugged mine in and waalaa!
Old 05-28-2004   #8
Enes
Enes's Avatar
The RPM wire did you guys just pull the wire from the ecu or somewhere from the engine bay?
can you get me close to where the rpm sensor is.. i don't have time to do the research and abviously you have already done it..
-E
Old 05-28-2004   #9
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
CAS???
7/25/09
Old 05-28-2004   #10
Yea Imnot sure about on a 2G, but on my 1G You tap the black wire (pin 2) on the CAS to the White wire from the MAFT
Old 05-30-2004   #11
Enes
Enes's Avatar
ok, i did the same thing there was NO lights on mine either but then again it probably goes away as you turn the car on, i couldn't look and turn it on at the same time .. i need to work on my speed of being in 2 spots at the same time... ..
will let you know more sooner... now its RTFM time..
-E
Old 05-30-2004   #12
Enes
Enes's Avatar
ok, i didn't do anything special with it, just pluged in two ends and it worked... just put some dielectric grease on both plugs and pluged it in. started the car just fine.. no issues what so ever.
did you figure out your problem?
-E
Old 05-31-2004   #13
ehh no, i just got back from chicago and was thus gone. i'll just keep driving around on the mas till i get some IC pipe action....which most likely means more problem posts will appear here
Old 05-31-2004   #14
Enes
Enes's Avatar
ill take a pic of my setup,, its super simple, but it works.
-E
