Old 09-04-2012   #1
J-pipe leaking at flange, one bolt hole stripped.
What is my best fix for this?
I want to race tomorrow and I'm sure this is my issue. I'm thinking of just driving to a welder and welding the 2 together.
I hate J-pipes.
I'm all ears.
Aaron
Old 09-04-2012   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: J-pipe leaking at flange, one bolt hole stripped.
Post a pic so we can see what hole is striped. Im thinking a stud JB welded into the comp housing at least as a temp fix. I agree J-pipes suck.
11.35 @ 120mph
Old 09-04-2012   #3
Its the top left hole.
Old 09-04-2012   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
heli-coil the turbo? That would be the best way in my opinion, or just drill/tap it out larger for a bigger bolt.
I've dealt with the leaky flanges, I just welded the pipe to the flange solid and called it good.
Originally Posted by shoutbox
Old 09-05-2012   #5
I figured it out, i just needed a spark to light my fire.
Thanks guys. I figured that I could run a thru bolt and nut. But I think when I get come I will helicoil the turbo for good measure.
If I was 100% keeping the turbo for a long time I'd weld it, but I think for resale most would be scared of having to change their FMIC a bit because if I was welding the J-pipe to it I'd just rotate the housing too.
Old 09-05-2012   #6
Besides that, it's not exactly easy to weld a mild steel j-pipe to a powdered aluminum compressor housing.
Old 09-05-2012   #7
Just retap the hole for a slightly larger bolt. done.
Old 09-05-2012   #8
Jungy
Jungy's Avatar
or helicoil it and never worry about it again
Old 09-05-2012   #9
I have a hot glue gun.
Old 09-05-2012   #10
This.
...and also this just for good measure
