Old 11-30-2012   #1
slammedndirty
slammedndirty's Avatar
Drives: 93 laser rs awd
no start 1g
Bought a 93 laser with bent valves. So I replaced the head. I have spark, fuel, compression 150 all the way across and timing is dead on. I just replaced the ecu as well.
I got the car running 4 days ago and it ran for about 5 seconds then slowly idled down and killed and it would do it over and over. when I went to try to start it this morning it won't start at all. still has fuel,spark compression and timing is still dead on..
Someone please help me!!!
i got a case of beer for the first person to come figure it out
slammedndirty is offline   Reply With Quote
Old 11-30-2012   #2
Re: no start 1g
is the coolant temp sensor unplugged or broken?
Old 11-30-2012   #3
slammedndirty
Re: no start 1g
plug is broken but i have it wired up to the sensor
Old 11-30-2012   #4
Re: no start 1g
if that connection isn't great the car wont start
Old 11-30-2012   #5
slammedndirty
Re: no start 1g
ok i will go recheck it now
Old 11-30-2012   #6
Re: no start 1g
Agree'd check that connection. Also check the CAS plug, and ensure the CAS itself is installed correctly (not 180* out).
Old 11-30-2012   #7
slammedndirty
Re: no start 1g
the one connection seemed a little loose so i crimped it down more and it attempted to fire.. but still nothing
Old 11-30-2012   #8
slammedndirty
Re: no start 1g
cas is good tested it on a buddys car and its putting out spark
Old 11-30-2012   #9
1999Gst
Drives: 1999 Eclipse,
Re: no start 1g
Check fuel psi at the rail
Old 11-30-2012   #10
Re: no start 1g
I'm not implying it's bad, i'm saying ensure it's connected fully, and ensure that when you installed it on your car, you did so correctly because it's easy to accidentally install it 180* out.
Old 11-30-2012   #11
Re: no start 1g
Other thoughts:
Massive vacuum leak
Verify all 4 plugs are sparking (maybe you have a bad coil, only running on 2 cylinders)
Base ignition timing (center the CAS in the slotted holes to start with)
BISS screw improperly adjusted
MAS bad or unplugged
Do you have a logger, or link, to look at some of these signals?
Old 11-30-2012   #12
slammedndirty
Re: no start 1g
Other thoughts:
Massive vacuum leak
im buying a logger today hopefully and there is spark on all 4.. i will check the others
Old 11-30-2012   #13
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: no start 1g
Ive started my car, both with a bad ECT sensor and a maf that is unplugged. Make sure to check for a bad and weak coil pack as well. You said you verified spark? And how do you know youre getting fuel? Pulled the plugs and smelled them or lf they are wet? Check youre fancy relay under the the radio as well. Ive ran in just about every no start condition there is on these darn things...sometimes its really simple other times it could be intermittent...also I did not hear you mention you checked your main block fuses check those as well.
Old 11-30-2012   #14
slammedndirty
Re: no start 1g
Vacuum leak mixed with a bad maf.. Got it running thanks guys
Old 12-22-2012   #15
slammedndirty
Re: no start 1g
So i got the car running and drove it a couple times around the block. Let it sit for a couple days cause i have been busy with work, and now it wont start again. Has fuel spark compression and timing is on..... Any other suggestions ?
Old 12-22-2012   #16
Re: no start 1g
What do the plugs look like?
Old 12-22-2012   #17
Re: no start 1g
Old gas?
