Old 11-02-2003   #1
jd1828
Send a message via AIM to jd1828
I have a set of arp head studs that im putting on a 6bolt. what torque do i use for them? what do i have to do to make them fit? just cut off a part of the engine mount, right?
jd1828 is offline   Reply With Quote
Old 11-02-2003   #2
WHy would you have to cut off part of the engine mount?
Old 11-02-2003   #3
jd1828
in order to drop the head on there is a part of the mount that has to be taken off. im not sure if it has to be done but i will be a lot easier with it removed. i know that you cant take the head and exhaust manifold off together with out taking it off.
Old 11-02-2003   #4
Yeah, I forgot I read that somewhere.
Old 11-03-2003   #5
If you don't cut that part of the engine mount off then you have to remove the alternator and power steering pump everytime you take the head off. Most people are going 85 - 90 ft/lbs with moly lube. I think ARP recommended 78 ft/lbs.
