Old 03-28-2013   #1
dsmdion
dsmdion's Avatar
1GB Talon 1k
Bought this car from a buddy with a blown engine and was going to put it back together, but I bought an Evo IX DD instead so this car is up for sale now
Chassis - wally 255, 4 bolt lsd rear, abs delete (still has abs hubs) kyb gr2 struts, braided clutch line, 2g maf wired in, ecu plugs rewired, clutch cut wired just lots of wiring to fix things. factory aluminum rad, all clean interior, new clutch master, good clutch pedal assembly, comes with rust free fender and hood, clean bumper, boost gauge goes to 20psi
Trans is a 93 I believe, 23 spline transfer case, filled carriers in the drive shaft shifted just fine when warmed up.
Head is rebuilt 3 angle valve job 3g lifters, black top cam angle sensor,
IDK if the head is still good, polished tb, polished tb elbow, polished thermostat housing, brand new starter with life time warrant at autozone, new water pump with life time warrant at advanced i believe, new front cover.
Poly motor mounts, 2g maf with intake, 2g exhaust manifold, 2 1/2 inch shit exhaust, factory battery tiedown, rear diff fluid is shock proof and 80 or 90 weight mixed adjustable shift linkage, skateboard bearing mod, solid shifter base bushings, afc wiring is wired in already, newer viscous coupler in the trans, newer power transistor.
Also comes with
Cyclone Intake Manifold
3 2.3L Ross 9:1 comp. 6 bolt pistons
N/T Block
6 Bolt stock Rods
1G Flip key
Basically the car needs a motor, ecu, and injectors to get running. The car is actually in pretty descent shape, and would make a good project.
$1000 takes it all
$850 if you take it By next weekend
EDIT-comes with 3000GT wheels, not the wheels in the pics
You can PM, or text me. Number is 608-797-2777
Thanks
ID:	13461   Click image for larger version
ID:	13462   Click image for larger version
dsmdion is offline   Reply With Quote
Old 03-28-2013   #2
99gsxjoel
Drives: 1999 GSX
Re: 1GB Talon 1k
Damn
99gsxjoel is offline   Reply With Quote
Old 03-28-2013   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 1GB Talon 1k
Paging eclipseGST!
I'd come get it but that is way to far!
Old 03-28-2013   #4
dsmdion
dsmdion's Avatar
Re: 1GB Talon 1k
I think Jake has problably seen this car too, he knows the kid who owned it.
Old 03-28-2013   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: 1GB Talon 1k
Yep... Its a nice clean car! Definitely vouch for the car and the seller. Not a 1g guy. Come get it Nick (Cornfed)... Its not that bad of a drive! haha
Originally Posted by shoutbox
Old 03-28-2013   #6
4seasons69
4seasons69's Avatar
Re: 1GB Talon 1k
If I had 1k! glws
Old 03-29-2013   #7
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 1GB Talon 1k
Jake ill pay you to trailer it up here but you gotta bring the green 1G to.
Old 03-29-2013   #8
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: 1GB Talon 1k
I could bring it but the green 1g is on the lift getting parted right now.
Old 03-29-2013   #9
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 1GB Talon 1k
Yeah buddy.
I am interested though
Old 03-29-2013   #10
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 1GB Talon 1k
I'm out!
GLWS though.
Old 03-29-2013   #11
dsmdion
dsmdion's Avatar
Re: 1GB Talon 1k
Also comes with a good 6 bolt crank that should just need a polish. and any other MISC. 1G parts I can find lol
Old 03-29-2013   #12
Re: 1GB Talon 1k
Wouldn't mind taking some body parts if it ends up getting parted and stripped.
Old 03-30-2013   #13
dsmdion
dsmdion's Avatar
Re: 1GB Talon 1k
Can probably close this thread, car is going to be parted if anyone needs anything Ill start a new thread
Old 03-30-2013   #14
Re: 1GB Talon 1k
I'd like front bumper and passenger fender if possible. Maybe hood.
Old 03-31-2013   #15
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: 1GB Talon 1k
Possibly in for the 4 bolt rear setup and a driver's side fender!
Old 03-31-2013   #16
dsmdion
dsmdion's Avatar
Re: 1GB Talon 1k
well the whole car is pending sale now, Ill let you guys know, if it dont sell Ill start parting it.
Old 03-31-2013   #17
dsmdion
dsmdion's Avatar
Re: 1GB Talon 1k
Can officialy close this thread car is being parted
Thanks
Old 04-02-2013   #18
Re: 1GB Talon 1k
WTF
Old 04-02-2013   #19
Re: 1GB Talon 1k
What's wrong with the front bumper anyways? It looks good in the pictures here?
Old 04-02-2013   #20
dsmdion
dsmdion's Avatar
Re: 1GB Talon 1k
Paint is all peeling off that's why it has an bumper with it. It's not that nice trust me lol
