Old 05-19-2013   #1
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
FS: 3000GT TT Axles and stuff
I have a few pairs of twin turbo rear axles. I am tired of them sitting around. I've though about selling them on 3SI but they are heavy which makes expensive to ship. $25 shipping on a $40 part doesn't go over too well. They might go to a scrap yard soon, which seems like a waste of parts that will eventually be needed. If you come pick them up $10 each axle, I have two pairs in good shape, and two pairs with a little surface rust that would have to be cleaned off the splines.
I have one good passenger side TT front axle, from a 5 speed, not sure if they are different. $30
I have one bad passenger side TT front axle, from a 5 speed, not sure if they are different. $10 torn outer boot
One diver side half shaft and axle 5spd TT, torn inner and outer boot. $20
I also have one 5 speed and one 6 speed propeller shaft front sections. Both have a little surface rust on the outside of the yoke, not sure if they would clean up good enough to use, or if the shaft is the only part worth anything. $10 each.
5 speed rear pumpkin. Had a leaking front pinion seal I think, was also disassembled for a research project. $10
All prices are picked up in Wayzata, delivery extra.
