Old 07-03-2013   #1
95tsi
95tsi's Avatar
Drives: a pos
Thumbs up '95 Talon Tsi
Her it is, my baby. I've owned this car since 2002 I believe. Began as a stock 7 bolt with 58,xxx miles. As of now I believe It is at 112k on the clock and about 6k on rebuilt 6 bolt. So onto the goodies, I will get pictures up when I figure out how to off my phone.
Engine:
Map built 2.3 crower rods wisco pistons
Arp head studs
Some good parts in head but can't recall what...
Comp 101200 cams
Mitsubishi head gasket
New oil pan and front case at rebuild
Fuel
Rewired walbro 255
Pt 880cc injectors
Stock fpr
Air
E316g 29psi
Injin intake
K&N style filter
Hahn fmic
Archer 2.25" ic pipe with custom piping lowers
Ported stock O2 housing
Hahn 3" downpipe(I think it has been on the car for 8yrs)
Greddy 3" catback no cat.
Magnus intake manifold with custom welding added
Drivetrain
Archer kevlar street disc
Archer 2600 pp
Fidanza lightweight alum flywheel
Shepard stage 2/3 tranny
Lacroix installed 4 spider center diff
B&M short throw shifted
Solid shifter bushings
Suspension
Stock rear sway bar
RM front sway bar(rear bar included with sale)
Koni yellow 5pt adj shocks
Ground control coilovers
Hyoercoil springs 650f/450r
Coaxial bearing perches
Poly bushings
Interior/gauges
Stock grey cloth inter.
Triple gauge a pillar pod(autometer boost, egt, afr)
Plx wideband afr mounted over steering wheel
Pc680 battery
Pioneer deck stock speakers
I'm sure I'm forgetting things. This list is just what I can remember off hand. This car has seen lots of passes at brainerd running 11.7 at 119. I set it up for a very well rounded car to keep up with most everything straight line or the turns. Dynod 347hp/361tq at DB on E85 and 29psi. Sunroof is plagued by typical 2g being a plastic pos, I pulled the fuse and leave it shut. Window trims could use paint. Front bumper cover is off a 97tsi and is a shade off on paint. Interior is in good shape, exterior had been painted yrs ago and is in good shape. Colorado car originally and very clean because of it not a 2g that bucket. Would like to see $7500 if I am too car off on my pricing please let me know. Dsmlink v2.5 and laptop included with sale. This will be very painful to sell but I'm moving to Montana and I don't foresee much use of a car like this there. I would much rather someone get some use out of it in ways I will not.
