Old 07-04-2013   #1
twisted954
Possible Head Trauma
twisted954's Avatar
Drives: after suspension
Misc Parts for sale - All parts OBO
UPDATED BELOW ON LAST POST
APEXI AFC - Old school blue face unit. Harness was cut short for wiring fitment, but still plenty left to wire there: 150.00
13G 1g Auto turbo - Here is an upgrading gem...this 13G literally had less that 40K on it when pulled...there is NO shaft play...the turbine housing has NO cracks...it's in good shape, run it as is in an auto...salvage it for parts to build it...I don't care - 100.00
I have an oddball custom housing for a mitsu frame housing, it's hard to explain how I came about owning it, but essentially it's a cast housing that accepts a 16g/mitsu turbo but is in a t3/vband configuration .63 AR from my memory. Anyways, I used to to limp myself into a t3 setup...I do have a o2 housing to go with it if you want. ALL Stainless flanges with a recirculated dump...this obviously would work with a custom manifold or specifically with the MAP DSM Manifold it was patterned after... 100.00 for the housing and add 50.00 for the o2 housing if you want it
I have a set of Manley Turbo Tuff I beams for 7 bolt DSM EVO for sale...3 in perfect condition, 1 was honestly on a spun bearing...no discoloration, but it should be resized OR replaced before assembly if you build on this set. I would do 300.00 for the set...if you get it resized you would be into a set for 350.00 or so total which is a steal...again, these aren't H beams...these are Manley turbo tuff I-beams
I have an old t3 single scroll 2 bolt 38mm manifold for DSM with o2 housing I never used...I believe it was an Ebay manifold that was designed to be a DNP knock off or something to that effect. I think the T3 bolt holes were slightly off...a drill and some nuts would allow this to be used. I would let the set go for 100.00
I have a few misc things laying around too...some used lifters I just never re-used for 10.00...I have a set of 3 mahle pistons in great shape I have been saving for a backup build which are in great shape...they just need the 4th piston to be replaced and rings all around...I don't even remember what happened to the last one...anyways, they are used...let's talk 150.00 for the set of three. Pick up the piston and rings for another 180.00 or so and you are STILL saving a pile of money. I believe these are .020 over.
I will add parts later as these sell or I think of more stuff I have for sale...I have quite a few piles of DSM and EVO parts
Faster than pushing...
twisted954 is offline   Reply With Quote
Old 07-07-2013   #2
twisted954
twisted954's Avatar
Re: Misc Parts for sale - All parts OBO
Again, all things OBO
Old 07-07-2013   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Pics of t3 twin scroll
Old 07-08-2013   #4
twisted954
twisted954's Avatar
I can post up pics of anything you want...BUT, did I say t3 twin scroll? If I did, I apologize...I meant T3 undivided...my bad...let me know if you still want pics
Old 07-09-2013   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Either way is cool.
Old 07-20-2013   #6
twisted954
twisted954's Avatar
All parts still here...ALL parts are best offer
Old 07-21-2013   #7
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
I sent you a PM a few weeks ago about the manifold. I'm still waiting to hear back.
Old 07-21-2013   #8
twisted954
twisted954's Avatar
That's so strange...I show I responded to that in my inbox...my bad...followed up
Old 07-26-2013   #9
twisted954
twisted954's Avatar
Bump-a-roonie
Old 07-31-2013   #10
twisted954
twisted954's Avatar
obo peoples...lol
Old 09-12-2013   #11
twisted954
twisted954's Avatar
NEW UPDATED PRICING!
APEXI AFC - Old school blue face unit. Harness was cut short for wiring fitment, but still plenty left to wire there: 100.00 OBO
I have an oddball custom housing for a mitsu frame housing, it's hard to explain how I came about owning it, but essentially it's a cast housing that accepts a 16g/mitsu turbo but is in a t3/vband configuration .63 AR from my memory. Anyways, I used to to limp myself into a t3 setup...I do have a o2 housing to go with it if you want. ALL Stainless flanges with a recirculated dump...this obviously would work with a custom manifold or specifically with the MAP DSM Manifold it was patterned after... 50.00 for the housing and add 50.00 for the o2 housing if you want it
I have a set of Manley Turbo Tuff I beams for 7 bolt DSM EVO for sale...3 in perfect condition, 1 was honestly on a spun bearing...no discoloration, but it should be resized OR replaced before assembly if you build on this set. I would do 150.00 for the set...if you get it resized you would be into a set for next to nothing l...again, these aren't H beams...these are Manley turbo tuff I-beams
I have an old t3 single scroll 2 bolt 38mm manifold for DSM with o2 housing I never used...I believe it was an Ebay manifold that was designed to be a DNP knock off or something to that effect. I think the T3 bolt holes were slightly off...a drill and some nuts would allow this to be used. I would let the set go for 75.00
I have a few misc things laying around too...some used lifters I just never re-used for 10.00...I have a set of 3 mahle pistons in great shape I have been saving for a backup build which are in great shape...they just need the 4th piston to be replaced and rings all around...I don't even remember what happened to the last one...anyways, they are used...let's talk 75.00 for the set of three. Pick up the piston and rings for another 180.00 or so and you are STILL saving a pile of money. I believe these are .020 over.
