Old 08-23-2013   #1
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Valves
In need of a full set of valves. std size only. lmk what you have.
NEED ASAP!!
Mark
BW8776, e-85
Old 08-23-2013   #2
mark4g63t
mark4g63t's Avatar
Re: Valves
Head is at the machine shop and just needs a new set of valves. last set one valve was a different size. Need to make the cookout!
BW8776, e-85
Old 08-23-2013   #3
golden763
Drives: 95talon tsi
Re: Valves
Just stockers?
Old 08-23-2013   #4
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: Valves
If stock would cut it I should have some. If not I suggest these:
http://www.ebay.com/itm/4G63-stainle...item5af4670f23
Cheap and a lot of people like them. There are a few with 8xx+ hp with those too.
Edit: If you're wanting to have the car at the Cookout I'm probably of no help.
Old 08-23-2013   #5
mark4g63t
mark4g63t's Avatar
Re: Valves
Ended up grabbing a complete head from cornfed and found a valve that will work for my other head. All is good now! Just have to decide which head to use/ build.
BW8776, e-85
Old 08-24-2013   #6
Re: Valves
If you have a 2g head I would use that.
Old 08-24-2013   #7
mark4g63t
mark4g63t's Avatar
Re: Valves
They both are 2g heads. I'm about to put it on then will have some questions about timing belt installation.
Thanks guys!
BW8776, e-85
