Old 08-26-2013   #1
97gsexx
97gsexx's Avatar
Drives: 97 talon
Assistance diagnosing a no start issue
Hey guys, so I put my car together and am not having luck getting it to start. It doesn't tick, turn over, or attempt to start in any way. Also, my left turn signal doesn't stop flashing no matter what position the switch is in. The right turn signal doesn't work at all except for when I turn my hazards on. Took the steering column off and examined switch/harness/wires and everything looks good. Pulled the stereo and checked the relays and everything looks good as far as I know. I have read that the switch itself can cause this so maybe I will just order one. Starter is plugged in and grounded, however it doesn't make a sound or do anything when I try to start it.
I then did more research and came across a similar issue and the culprit was the anti theft system. So I tried opening the door, locking it allowing the security light to come on, then closed it, then unlocked it from the outside to turn the system off and still no luck.
I just installed a black top cas and 6 bolt swap harness as well. The previous owner had the metal top style cas and wired it in instead of using the harness that plugs into the crank sensor connector. I cut the three wires that were wired into it when I removed the metal top cas and then cut the a/c connector sensor since I am not using it, and then wired the three wires into it and plugged the other end of the cas harness into the a/c sensor to replace the crank sensor connector because there isn't one on the car. I connected the white wire to the blue wire and followed the instructions on the magnus site. Car still doesn't start.
I have honestly tried everything I can think of and would really appreciate it if you guys could give me a suggestion on what to check or possibly lend me a hand diagnosing the issue. I would gladly throw some $ your way and of course supply the beer. My car has been dead for a while and just really need to get it out of my buddy's garage and have a car to drive to work and school. Thanks a lot!
97 gsx (sold)
97 talon tsi awd 🐼
