Old 11-19-2013   #1
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
WTB/WTT 5 SPEED AWD SWAP
Looking to purchase a 2G 5 speed AWD swap or Will trade for an AWD auto swap that I have which would include everything.
Will need rear differential, axles, t-case, and tranny....I think thats it
Parts are from a 95 GSX
call/text 952 807 1021 or pm me If you have anything.
Mark
BW8776, e-85
Old 11-19-2013   #2
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: WTB/WTT 5 SPEED AWD SWAP
I should have something for you soon, if you still need it this weekend.
Style's automotive engineer
Old 11-20-2013   #3
mark4g63t
mark4g63t's Avatar
Most likely wont be doing the swap until it gets closer to spring, so i'm in no rush.
BW8776, e-85
Old 11-21-2013   #4
punxnotdead185
Drives: 95 AWD Mirage Coupe with AIDS
I know the starter plates are different between the two also.
punxnotdead185 is offline   Reply With Quote
Old 11-23-2013   #5
mark4g63t
mark4g63t's Avatar
Well A little change in plans. No longer looking to purchase, Just a straight up trade. I will include the shifter assembly as well.
punxnotdead185- Thanks for the tip, I almost spaced on that one.
BW8776, e-85
Old 12-04-2013   #6
mark4g63t
mark4g63t's Avatar
I know someone out there has a 5 speed setup!
BW8776, e-85
Old 12-05-2013   #7
mark4g63t
mark4g63t's Avatar
Would also be interested in the 3 bolt 1g non lsd rear diff. If anyone has one laying around.
BW8776, e-85
Old 12-14-2013   #8
mark4g63t
mark4g63t's Avatar
Bump, Still Looking!
Really don't want to have to deal with shipping.
BW8776, e-85
Old 12-16-2013   #9
mark4g63t
mark4g63t's Avatar
Only need the Trans, T-case, and front axles. Ended up getting the 5-speed ring and pinion gear set for the rear diff.
BW8776, e-85
Old 12-17-2013   #10
mark4g63t
mark4g63t's Avatar
Just need Trans and T-case, maybe a flywheel but i'm pretty sure I have one laying around.
BW8776, e-85
