Old 01-27-2014   #1
FS: Auto swap parts
I have a full auto swap for a 2G for sale. Trans with shift kit mods done to it, transfer case, read diff, axles, shifter, bunch of other parts. Could possibly be used on a 1G also like the Jeff Bush/English Racing 1G.
Old 01-27-2014   #2
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: FS: Auto swap parts
So tempting to go auto instead of built manual. I just don't know if I could take it not pretending I'm cool shifting with a clutch
Old 02-01-2014   #3
dsm_talontsi
dsm_talontsi's Avatar
Drives: 91 Eclipse GST
What would be needed to run in a 1g? I'm starting to do a lot of research on going auto. Seems cheaper and more reliable then building a 5 speed setup.
Old 02-01-2014   #4
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
The only parts that will work for you car would be the trans and mabey the Tcase.
You'll need a lot of parts to make this work. you'd almost be better off buying a clean auto AWD and swap your parts into it. or buy a 1G auto donor car.
11.35 @ 120mph
