Old 04-02-2014   #1
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Crank But No Start
Hey guy's so I had sold that 98 Eclipse RS and the guy came to pick it up today and it has a crank but no start symptom.
I HAVE CHECKED:
Power at pump...There is none.
Ground at pump and it has ground.
Jumped the fuel pump with a battery and it works fine.
Power at the relay and it has power to everything but the fuel pump wire (black W/ blue stripe) Have tried 2 new relays with same results
I have jumped the relay from the voltage source going to the relay that has power to the fuel pump wire (B/BL) and it activated the pump fine.
Checked for power at the ASD relay and it gets power, Also replaced this relay at the same time as the Fuel pump relay.
It did pop the main engine fuse and would pop it immediately upon inserting a new one so I thought short somewhere or the computer kicked it out. Unplugged the batt. for 10 mins and hooked it back up to rule out computer and it hasn't popped the fuse yet.
I also noticed that the check engine light doesn't come on at all when turning the key from off to the on or start position (no flashing) Any thoughts on this? Was told that it means the computer is bad.
BW8776, e-85
