Old 05-29-2014   #1
big garage clean up
Garage dsm clean up
All parts as is and are plus shipping and paypal fees
link with all the pictures
http://s122.photobucket.com/user/tkr...?sort=3&page=1
1. 1g hot pink fuel rail 25.00
2. 2g smic 20.00
3. 1g wing unknown brand urathain came off wifes 90 45.00
4. 2g black pass side door vent 20.00
5. 2g power mirrors 40.00 set
6. spyder manuel top switch 5.00
7. dash top switch 15.00
8. 2g black has,defrost switches 10.00
9. 2g key less ecu
10. left door harness 10.00
11. right door harness 10.00
12. right rear window motor 20.00
13. spyder left and right body door seals 15.00 set
14. Spyder trunk lid seal 20.00
15. Spyder trunk and gas door levers 10.00
16. 2g black left power mirror cover 5.00
17. top ecu 20.00 each x2
18. 2g black dash defrost vent 5.00
19. spyder top motor 25.00
20. 2g black left door vent 10.00
21. 2g black right power mirror cover 5.00
22. 2g heater core 30.00
23. 2g clutch resovor and bracket 10.00
24.
25. din pocket 5.00
26. 2g dead peddle 5.00
27. 2g greddy mas v. stack 10.00
28. 2g power transistor 20.00
29. timing belt pulleys idle and tension 5.00 each
30. 2g keys and ing locks 15.00 each
31. 2g 98 clock spring (48K on it) 10.00
32. horn 5.00
33. black haz button 5.00
34. grey dimmer 5.00
35. black streering wheel cruise switch 5.00
36. 1g upper water neck 10.00
37. 2g 95 cas sensor 25.00
38. 2g black pass door switches 25.00
39. 2g black door handle covers left and right 10.00 set
40. 2g wiper arms 2 sets 20.00 a set
41. 2g right lsd axel cup 40.00
42. Spyder trunk shocks 30.00 set
43. black map light mirror 20.00
44.
45. dipstick tubes 5.00 each
46.
47. 2g blower motor 15.00
48. 2g alt. 45.00 each x2
49. 2g coil pack 30.00 each x2
50. 2g brake booster (48k on it) 20.00
51.
52. 2g water neck 10.00
53. cam covers black,silver,silver cut 10.00 each
54. 2g black radio bez 10.00
55. alt arms 5.00 each
56. balance belt gear and tensor 10.00
57. 2g 95 auto cams 30.00
58. 6bolt rear main seal housing 10.00
59.
60. 2g rear caliper brackets 10.00 each
61. 22 spline out put shaft 10.00
62. 1g door handles outer 10.00 each
63. 2g fuel feed line filter to rail 5.00
64. 2g hood latch 10.00
65. inspection plates 5.00 each
66. tranny bolt on shifter levers 10.00 each
67. lower timing tins 10.00 each
68. 1g speedo sensor 10.00
69. 90 shifter cable brackets 10.00 each
70. 2g coil wiring harness 5.00
71.
72. oil pressure light sensor 5.00
73. oil pressure gauge sensor 5.00
74. 93-02 mirage radio brackets 10.00 set
75.
76. rear engine lift mounts 5.00 each
77. crank balance belt gear 10.00 each
78. crank timing belt gear 15.00 each
79. oil pump timing belt gear 15.00 each
80. spyder top latch 10.00
81. safc ect holders 10.00 each
82. Eng relays 10.00 each
83.
84.
85. 2g auto tranny mount bracket 10.00
86. 2g ps bracket 10.00
87.
88. 2g clutch master 15.00
89. 6bolt hydro tensioner 30.00
90. ps heat shield 5.00 each
91. front engine lift brackets 10.00 each
92. head timing cover tins front and rear 5.00 each
93. 2.4 dohc front head timing cover tin 5.00
94. 6bolt crank spacer tin 5.00
95. 7bolt crank spacer tin 5.00
96. 2g block ps brackets 10.00 each
97. 7bolt hydro tensioner arms 5.00 each
98. 2g crank pulley 35.00
99. 7 bolt rear main seal housings 5.00 each
100.
101. 1g water pump pulley ps 5.00
102. 1g water pump pulley alt 5.00
103.
104. 2g oil pick up tubes 5.00 each
105. 2g red gas door 10.00
106. 2g awd auto flex plate 10.00
107. 2g crank scrapers 10.00 each
108. 2g knock sensors 20.00
109. 1g oil pick up tube 5.00
110. 2g upper engine block mounts 25.00 each
111. cam gear set 15.00
112.
113. 2g water pipe 10.00
114.
115. 2g bare t.b. 15.00
116. balance shafts set 15.00
117. k&n air filter small 3.5in inlet 15.00
118. 2g stock stock smic piping 5.00 each
119. greddy bov adaptor 2g 15.00
120.
121. 2g lower radiator hose 5.00
122. k&n filter ovel 3.5in inlet 15.00
123. 90 2in to 2.5in cupler 15.00
124. 3.5in S.S. piping 35.00 all of it
125.
126. home made 4bolt o2 housing rec for tail 38 on cast mani 25.00
127.
128.
129.
130.
131.
132. Greedy 60mm peak hold egt gauge 80.00
133. clifford concept 600 alarm system 60.00
134. 2g auto tranny mount 20.00
135. Awd tranny end case 20.00
136. Awd tranny bearing case 20.00
137. 6bolt water pump 3k on it 15.00
138.
139.
140. 2g shifter cables 50.00
141.
142. 6 bolt hydro tensioner arm 10.00
143.
144. 2g auto Awd starter plate 10.00 each
145. 2g auto fwd starter plate 10.00
146. 1g 5speed fwd starter plate 10.00
147. 1g alt. 40.00
Will add as i find more and take sold stuff off the list.
Old 05-29-2014   #2
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: big garage clean up
I'll take the isc
Old 05-30-2014   #3
97gsexx
97gsexx's Avatar
Drives: 97 talon
I will take the clutch master cylinder please sir.
97 gsx (sold)
97 talon tsi awd 🐼
Old 05-30-2014   #4
Shoot me a text
Old 05-30-2014   #5
97gsexx
97gsexx's Avatar
Drives: 97 talon
I recently got a new phone and lost your # so if you could pm it that would be great!
97 gsx (sold)
97 talon tsi awd 🐼
Old 05-31-2014   #6
7633007429
Old 06-19-2014   #7
Updated
Old 06-27-2014   #8
Sold
Gst tranny
Exedy p.p.
2g slave
2g alt pully water pump
2g ps pully water pump
2g oil pumps x2
2g 450cc injectors
1g water pipe
2g starter plate
