Old 06-09-2014   #1
bigboostingst
bigboostingst's Avatar
Drives: AWD Spyder
Sale: COMPLETE AWD Swap (EVERY PART NEEDED) *LSD rear end*
I'm selling a COMPLETE AWD swap. If you're interested in doing an AWD swap, this is literally every part needed to the last bolt. I've done an AWD swap before and having every part needed will make the job easy enough to complete in a long weekend. I'm looking to get $1600 for everything removed from the shell.
Parts included:
2gb AWD Transmission
LSD Rear differential with rear axles
6 bolt ACT flywheel (freshly resurfaced)
Awd Transfer case
Drive shaft and carrier bearings/bearing mounts
AWD front axles
Complete rear sub frame assembly
AWD gas tank, shield, and straps to mount to car
Gas tank connectors (pig tails) for sending unit and fuel pump
2g AWD rear subframe bolts
AWD eBrake cables
Sway bar
Starter
AWD transmission backing plate
If you would like to take the parts off yourself (so you know where everything goes), I will sell the entire shell with the transmission for $2200
Feel free to text me anytime at 763-4OO-1235 with any questions.
