Old 07-09-2014   #1
blackrosenova400
blackrosenova400's Avatar
Re: Shari's 2009 Raliart
Well today has not been a good day for me and Shari. Shari was driving her Ralliart and she lost all movement. Transmisson seems toi be working as it goes through all gears. Unfortanatly it was put into park while transmisson was internally still moving and the parking pawl is not functioning so well anymore.
While car is on 4 stands and rear parking brake are set, I had her hold a front tire while I turned the other. I shouldnt have been able to turn it with her holding it. Driveshaft was not spinnning so that rules out the rear differential.
Drained the transfer case, fluid has slight metal flakes but nothing serious. Pulled the cover that you use to check pinion backlash, found no problems. Removed both front cv shafts and found no problems.
Next step, going remove the transfer case.
20g Mafia
