Old 07-15-2014   #1
Ryze
Drives: 98 Dodge Neon, 93 GSX Race car
The Lady. IIRA Ice race/ weekend warrior car
Well I'm sort of new here, so let me start out by introducing myself.
Name is Ryan. I joined here back in 09 when I had a 1G FWD turbo eclipse as a daily driver, was completely stock.
I am back now because I just recently picked up a 93 Eclipse GSX, that has been prepped for NASA PTC class (road racing). I purchased it to ice race with the IIRA (http://iceracemn.com) for more information on the series.
I have been ice racing for about 6-7 years now and with the recent years not having much luck with reliability in a Subaru, I decided to pick this car up.
Details about this car
All-wheel drive
'93 shell
6 bolt motor
2689 lbs without driver or fuel
193+ whp on 12 lbs boost
White interior and exterior
Currently raced on 93 octane pump gas
Engine:
Stock 2.0 liter DOHC motor with balance shafts removed.
Was rebuilt at beginning of 2007 season.
It has seen 9 race weekends.
Head is shaved
ARP head studs
16G turbo
Manual boost adjuster
Ported Exhaust manifold
3" downpipe Custom open exhaust to rear
2G MAF
Apexi AFC controller (5 knob)
Aftermarket fuel injectors (size unknown)
Walbro 190 fuel pump
Magnecor 8.5 mm ignition wires
K&N air filter
Custom pipe between intercooler and throttle body with 1G BOV
Urethane motor/tranny mounts
relocated stainless turbo oil feed line
Earlier 1G oil cooler (fin-type)
5W-40 synthetic oil
Drivetrain:
Stock 5 speed transaxle rebuilt at beginning
of 2007 season
Archer Racing center diff
Short throw shift kit
ACT 2600 clutch
stainless cluth hydraulic line
Factory 3 bolt rear LSD
Red Line fluids used
Suspension:
'Muellerized' JIC dampers/coilovers with full race spring rates and camber plates
Offset poly bushings on front lower control arms
15/16" rear sway bar
Front strut bar (bolt-on)
Rear strut bar (weld-in)
Front camber -2.5
Rear camber -1.5
0 toe front and rear
Cross weighted at 50%
Momo steering wheel
Brakes:
Front calipers: Wilwood aluminum 4 pot
Front rotors: Wilwood 13" x 1.25"
Polymatrix H and B compounds front pads
Stock rear calipers with functioning hand brake
Porterfield rear brake pads
Adjustable rear brake bias
ABS removed
Brake master cylinder stiffening bracket
Stainless brake lines at corners
ATE Racing brake fluid used
Wheels/Tires:
4 Enkei RP03 Racing wheels 17x8.5 w/ 35 mm offset
Miscellaneous:
Carbon fiber hood vent
Oil temp gauge
Volt meter
Boost gauge
Baffled gas tank with modified low fuel light
Interior gutted except for dash
HVAC functional
A/C removed
Race specific:
Autopower 6 point bolt-in rollcage
(SCCA and NASA legal)
2.5 fire bottle bolted to passenger floor
Wink mirror
Optima red top battery relocated to rear
Kill switch mounted in dash
Doors gutted and glass removed
hood release cable removed;
2 hood pins installed
Hood gutted
Bumpers removed
Sunroof deleted via sheet metal and rivets
weld-in bung on downpipe for wide-band 02 sensor
intermediate driveshaft safety wired
turbo safety wired
I received the car July 13,2014. I purchased it without any of the safety equipment (seat, harness or window nets) Luckily I had all these items in my garage from my Subaru.
I immediately took inventory of all my spare parts, and what I need to get the car ready for IIRA ice racing in January.
July 14, 2014
I installed window nets and started planning on what I need to do to install the seats. I also removed all the sound deadening from the floors.
What parts I need
passenger side wiper arm
HVAC knobs
stock headlights
stock driver side seat rail
stock 14" wheels
base eclipse front brakes
I would like to sell the front brakes/ rear pads with spares.
and the wheels as these are not needed for ice racing at all
Things I need to take care of before hitting the ice
Mount seats
Mount fire extinguisher
fix blower motor
wire headlights/tail lights/ aux lights
mount harnesses
install wideband
remove injectors and get them cleaned and flowed
(hopefully) purchase DSMlink and tune
fix oil leak at the turbo drain tube gasket at oil pan
(hopefully) get a FMIC
install radio system
install datalogging system
remove rear glass and replace with plastic
make removable front windows with plastic
front splitter
sideskirts
rear lip wing
install stock base brakes
replace all fluids.
Remove misc weight.
Here is a few more pictures for your enjoyment
I will keep this updated as things go on. if anyone has any of the parts I am looking for LMK asap.
Thanks
Ryan
Ryze is offline   Reply With Quote
