Old 07-20-2014   #1
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
WTB: 2g Awd Gas Tank
In need of a awd gas tank for my 2g. Mine apparently has a hole in it that leaks after filling it with about $30 worth of gas.
9528071021
Mark
BW8776, e-85
Old 07-21-2014   #2
mark4g63t
mark4g63t's Avatar
Re: WTB: 2g Awd Gas Tank
Think I found the issue. The plastic spin on thing for the fuel pump housing looks to be the culprit, not sure if it's crooked or stripped.
BW8776, e-85
Old 07-21-2014   #3
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Is it possible you are installing it wrong with the gasket? Those can be tricky. No offense btw
Old 07-21-2014   #4
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
+1 for that. I've done it before on a friend's car before I had my license and it took a few tries. Then it were a few years until I did the pump in my 2ga. I just did that maybe a month ago or so. It took a few minutes to figure it out.
Old 07-21-2014   #5
blageo23
AWD4G64
blageo23's Avatar
I have a gas tank if it turns out to be anything else.
1998 Spyder AWD
567hp
490tq
Old 07-21-2014   #6
mark4g63t
mark4g63t's Avatar
Turned out that it is completely saturated and torn up pretty bad. I did Read that they could be tricky, so when the new one comes i'll be sure to take caution.
BW8776, e-85
Old 07-25-2014   #7
mark4g63t
mark4g63t's Avatar
asap. Well I need a new sending unit/ hanger. 2G AWD. or If someone is willing to weld an -AN fitting onto mine.
BW8776, e-85
Old 07-25-2014   #8
blageo23
AWD4G64
blageo23's Avatar
I drilled mine out where it meets the top of the sending unit then put a 90 degree barb to AN fitting there and used JB weld to hold it in place. Not very good pictures but you get the point.
ID:	14612   Click image for larger version
1998 Spyder AWD
567hp
490tq
Old 07-26-2014   #9
mark4g63t
mark4g63t's Avatar
Thought about doing that. I even went to db and got the fittings, but didn't want to mess with the factory pump o-ring piece thats on the other side so instead I ended up cutting one of the male -an's off drilled it out to match the line diameter and welded it onto the line. I'm hoping it will not leak. Last night I f'd up the hardline under the car trying to drill that out so my next question is, will it leak if I just put the hose over the line and clamp it down? It's the feed hose right after the pump.
Still interested in trying to find a sending unit just incase it leaks.
BW8776, e-85
Old 07-26-2014   #10
Yes it will leak. The the line on the car is bad you will have to buy a tank to engine an links kit.
Old 07-27-2014   #11
mark4g63t
mark4g63t's Avatar
Anyone have a tank to filter line with a male -an fitting?
or
A fitting for the fuel rail -6 AN (For the inlet, not sure if it matters)http://www.streettunedmotorsports.co...l_fittings.htm
Going to be putting this in with it.
BW8776, e-85
