Old 08-12-2014   #1
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Fuel Pressure Issue
Whenever I get on it, it goes super lean (confirmed by wideband and feel/ sound of car)
I believe the problem is the Fuel pressure regulator because when I turn the adj. screw on the top it will lower just fine, but only raise to about ~38psi before it stops rising while still turning the screw in (I could bottom the screw out without it going past 38psi).
Other hypothesis is the fuel pump and or the rewire, because the fuel pressure would adjust just fine before fixing the fuel leak and doing the rewire.
I did check the fuel filter and it wasn't clogged or dirty, but I will be ordering a new one since I don't know this ones past.
Anyone know if this is a sign of a bad afpr? or fuel pump?
BW8776, e-85
