Old 08-21-2014   #1
Huge clean up sale.
Please put what number and what group it is in in replys to make it easy.
Will take parts off when they have been sold. As all used parts they are sold as is.
Prices are picked up. Shipping is extra so is paypals 3% fees
All the pictures are in this link below.
http://s122.photobucket.com/user/tkr...src=wap&page=1
1g-6bolt parts
1. Hot pink powder coated fuel rail 25.00
2. Unknown urathain wing off wife's old 90 40.00
3. Upper water neck 10.00
4. Full t.stat housing 25.00
5. Rear main seal housing 10.00
6. Drivers outer door handles 10.00 each
7. Pass outer door handles 10.00 each
8. 22 spline out put tranny shaft 10.00
9. Speedo gear sensor 10.00 each
10. 90 shifter cable brackets 10.00 each
11. Hydro tensioner 30.00
12. Hydro tensioner arm 10.00
13. Crank spacer tin 5.00
14. Water pump pully alt 5.00
15. Water pump pully ps 5.00
16. Oil pick up tube 5.00
17. 5speed fwd starter plate 5.00
18. 90amp alt. 40.00
19. 92 cas 30.00
2g-7bolt
1. Auto Awd starter plate 10.00 each
2. Auto fwd starter plate 10.00
3. Auto tranny mount 10.00
4. Lower rad hose 5.00
5. Radiator oem style metal end tankes 30.00
6. Greddy bov adaptor 10.00
7. Stock lower smic pipe 5.00 each
8. Bare throttle body 15.00
9. Water pipe 10.00 each
10. Upper engine block mounts 20.00 each
11. Knock sensor 20.00 each
12. Crank scraper 10.00
13. Red gas door 15.00
14. Oil pick up tubes 5.00 each
15. Rear main seal housings 5.00 each
16. Crank harmonic pully 35.00
17. Crank spacer tin 5.00
18. Power steering brackets 10.00 each
19. Clutch master 15.00
20. Brake master 20.00
21. Coil wiring harness 5.00
22. Hood latch 10.00
23. Oem fuel line filter to rail 5.00
24. Rear caliper brackets L&R 10.00 each
25. 95-96 auto cams 20.00
26. Black radio bez 10.00
27. Water neck 10.00
28. Coil pack 30.00 each
29. Blower motor 15.00
30. 90 amp alt 40.00 each
31. Right rear lsd diff axel cup 40.00
32. Wiper arms 20.00 a set
33. Black door handle covers L&R 10.00
34. Black pass door switchs 25.00
35. 95 cas sensor 25.00
36. Black steering wheel cruise switch 5.00
37. Gray dimmer 5.00
38. Black has button 5.00
39. Horn 5.00
40. Clock spring (48k on it) 5.00
41. Black steering wheel w/air bag(48k on it mint) 40.00
42. Eng lock with key 15.00 each
43. Power transistor 10.00
44. Greddy filter adaptor 10.00
45. Dead peddle 5.00
46. Clutch resovor and bracket 10.00
47. Heater core 25.00
48. Black mirror covers 5.00 each
49. Black dash defrost vent 5.00
50. Black door panel plastics L&R 20.00
51. Key less door ecu 10.00 each
52. Black haz,defrost switchs 10.00
53. Power mirror set mint 40.00
54. Smic 15.00
Spyder only parts
1. Manuel top switch 5.00
2. Dash top switch 10.00
3. Door harness L&R 10.00 each
4. R.R. Window motor 20.00
5. L&R door seals body 10.00 each
6. Trunk seal 20.00
7. Gas and trunk levers 10.00
8. Top ecu 20.00 each
9. Top motor 40.00
10. Trunk shocks 20.00 set
11. Black map light rear view mirror 15.00
12. Top latch pass 20.00
4g63 parts
1. Awd tranny bearing case 10.00
2. Awd tranny end case 10.00
3. Balance shaft set 10.00
4. Cam gear set 1g,2g A&B 15.00 per set
5. Idle and tension pullys 5.00 each
6. Dip stick tubes 5.00 each
7. Cam gear covers 10.00 each
8. Alt. Arms 5.00 each
9. Balance belt gear and tensioner 10.00
10. Tranny inspection plates 5.00 each
11. Bolt on shifter levers 5.00 each
12. Oil press dummy light sensor 5.00
13. Oil press gauge sensor 5.00
14. Lower block timing belt tin 10.00 each
15. Rear engine lift mounts 5.00 each
16. Balance shaft gear 10.00 each
17. Oil pump gear 15.00 each
18. Eng relays 10.00
19. PS heat sheild 5.00 each
20. Front engine lift brackets 10.00 each
21. Head timing cover tins 5.00 each
All other parts.
1. 89 mirage radio brackets 5.00 set
2. 4g mirage radio brackets 5.00 set
3. CSM din pocket 5.00
4. Apexi safc ect holder 5.00 each
5. K&N air filter 3.5in inlet small 10.00
6. K&N air filter 3.5in inlet large oval 10.00
7. 2in to 2.5in 90 cupler 15.00
8. 3.5in S.S. Piping 35.00 all of it.
9. 4in steel exhaust piping 8ft+ 40.00 all of it.
10. Box of new steel manderal bends 180,90,45 100.00 box
11. 4 bolt rec o2 housing off parts car looks home made 15.00
12. Greddy peak hold 60mm egt gauge 50.00
13. Clifford concept 600 alarm system with all sensors 50.00
14. 4g csm, evo 1-3 shifter cables 25.00
15. 89 turbo csm drivers axel 40.00 (work also with 4g63 swapped 4g mirage and evo 1-3)
